Lighting HID/Xenon kits, Retrofits and Associated Topics
Lense reconditioning.
Old Oct 4, 2007 | 10:38 AM
MidShipCivic's Avatar
Default Lense reconditioning.
Who knows how to buff polish and smooth there head and tail light lenses ?
Can you guys post up some good info?
I don't know too much on how to do this.
Old Oct 4, 2007 | 11:43 AM
wreckeddc4's Avatar
Default Re: Lense reconditioning. (MidShipCivic)
go to http://www.lensrenew.com you can buy a do it yourself kit fot like $35 comes with detailed instructions
Old Oct 4, 2007 | 11:45 AM
I was expecting like some H-T write ups but this is good .
Modified by MidShipCivic at 3:57 PM 10/4/2007
Old Oct 4, 2007 | 12:13 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I wetsand starting with 1200 grit (maybe 1000 or 800 if the lights are really bad) and work my way up to 2000 grit. I start going back and forth, then when I go to the next higher grade, I sand up and down. I keep switching with each higher grade so that I can see if there are any scratches left from the previous grit.
After the 2000, the lenses look evenly hazy, but with no yellowish fading. I polish and buff with my Porter Cable random orbital using a yellow foam cutting pad and Meguiar's DACP, then wax by hand.
Before and after looks like this:
Old Oct 4, 2007 | 12:34 PM
Default Re: (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">I wetsand starting with 1200 grit (maybe 1000 or 800 if the lights are really bad) and work my way up to 2000 grit. I start going back and forth, then when I go to the next higher grade, I sand up and down. I keep switching with each higher grade so that I can see if there are any scratches left from the previous grit.
After the 2000, the lenses look evenly hazy, but with no yellowish fading. I polish and buff with my Porter Cable random orbital using a yellow foam cutting pad and Meguiar's DACP, then wax by hand. </TD></TR></TABLE>
Thanks whats the full name of DACP ?
Old Oct 4, 2007 | 01:53 PM
Community Builder
dual action cleaner polish
Old Oct 5, 2007 | 08:53 AM
Acuronda_SloTeg's Avatar
Hey I used 800 grit sandpaper first then did like three good treatments of turtle wax rubbing compound and wetsanded with 1500 and one more rubbing compound treatment and wetsanded real good with 2000 grit and hand waxed/buffed like everyone else. it worked real good.
Old Oct 5, 2007 | 08:55 AM
What is a rubbing compound?
Old Oct 5, 2007 | 10:12 AM
Community Builder
Default Re: Lense reconditioning. (Acuronda_SloTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Acuronda_SloTeg &raquo;</TD></TR><TR><TD CLASS="quote">Hey I used 800 grit sandpaper first then did like three good treatments of turtle wax rubbing compound and wetsanded with 1500 and one more rubbing compound treatment and wetsanded real good with 2000 grit and hand waxed/buffed like everyone else. it worked real good.</TD></TR></TABLE>
If you use successive grades of sand paper, like 800 -&gt; 1000 -&gt; 1200 -&gt; 1500 -&gt; 2000 then there is no need for rubbing compound in between sanding.
Jap_Spec_Imports
Mar 8, 2009 01:29 PM
welfarepc
Paint and Body
Aug 5, 2007 06:06 PM
anhthanh
Apr 6, 2007 05:44 PM
turbotime
May 4, 2005 08:49 PM
LSintegra
Oct 22, 2002 12:12 AM
