View Full Version : Lighting
Pages :
2]
11
12
13
- fog light install warm up?
- Interior Lights Problem 1997 Prelude
- My Ek Sidemarkers
- High Beams 93 Honda civic lx
- 90-93 integra one piece hids
- Turn signal failure
- HID Bulb Identification
- 96 Civic EK9, Headlights and Dashlights NOT Working
- Dome ligh issue.
- turn signal problem i need help
- Need Help
- Intersection light template needed. Jdm itr front end
- JDM ITR headlight reflector chrome flaking
- weird film or coating around headlights
- What is this? (ep3-rear bumper lights)
- IL4 headlights
- help reverse lights not working.
- Ebay retrofits?
- 1st Gen TSX, headlight issue, please help, need info
- HID headlight kits and LED bulbs upgrade
- Q45 retrofit, now what hid kit to get
- 94 EJ1 fog hook up
- 97 ek headlight issue
- Glass Headlights for 05 Accord
- Footwell/Floor Lighting Install on EG Civic
- headlight issues
- Trying to find the right HID kit (2013 Si)
- 94 eg fog lights (plz help!)
- 1996 acura integra cluster lightings not working
- OEM Fog light bracket
- H4 hid high/low little halogen bulb not working
- honda torneo 1.8L
- 2001 Honda torneo Fog lamp kit
- Important: Don't Forget to Clean Out the INSIDE of Your Lenses...
- ** Official LED Headlight Conversion Thread **
- Headlight Out
- LED Headlight and OEM Fog Issues: Amperage and Relay/Fuses
- pass side tail light doesnt work when lights are on. 98 DC integra
- Edm rear rog light wiring
- 4 pin light socket for flashing light
- 1990 honda accord ex. bypass fogs, turn on separately
- Denji headlights being produced again- Legit??
- Signal Lights Not Working But Hazards Do
- 03 CRV Left headlamps turn off when ignition is on
- Can anyone tell me the difference between these OEM EK/EJ fog light kits?
- Integra sequential tail light mod?
- Bulb clip question
- 3rd brake light/ Spoiler.
- 4DR OEM fog lights on a 2DR?
- LED retrofitted headlights?
- Recommendations for reliable Front Bulbs for 1997 Integra RS (3rd Gen)
- 2014 civic touring headlight changed
- Very first HID issue on my 95 Civic. NEWB. I need some help with this!!!
- led taillights 2000 civic si
- ef9 indiglo garnish
- 99/2000 civic side marker template
- Any ideas?
- 2001 accord headlight wiring diagram
- D16z6 engine wiring harness question
- 2014 accord hybrid headlight question
- Headlight electrical problem
- Leds
- DanGAvery
- DIY: Footwell LEDs on/off with Door
- Fog lights wiring
- LED cluster?
- Can anyone ID these tail lights?
- bixenon harness
- Civic HIDS
- 2014 Acura ILX 5000K HID Install - The Retrofit Source
- LED buyers: BEWARE of JDM ASTAR
- What color HIDs?
- Gauge pod alternatives?
- Fog/Driving Lights for 99 Accord LX
- Dash lights out
- "Small light" Short
- Which LED bulbs for 97 Civic?
- Lights flicker/pulse... at a loss
- Whats a good headlight bulb upgrade?
- 8000k hid kit not the right color temp
- FX-R vs. RX-330 for G3 Integra
- NO RUNNING LIGHTS
- FOGLAMPS EK 99-00 bulb code hid
- no blinkers/hazards left dash indicator solid won't turn off, nothing on the right
- hid kit removal
- Stupid, Stupid Headlights
- Eg High-Beam, dome light, and reverse light!
- brake lights acting strange on accord
- dome light /center mods
- Anyone interested in getting in on a GB for a full retrofit kit from TRS?
- EK Coupe 99 Taillights Uneven
- Retro fitting for a 2013 honda civic si
- Single Headlight issue
- Best fitting capsules for DB
- Fogs dont work at all :'(
- Jdm front integra hid install
- Having an issue..
- Depo FX-R retrofit
- where the heck can i find h4h bulb
- 2012 Civic HID
- Question on corner light bulb
- Help!!! HID lights keep going out!
- Any retrofitting services in Central FL? I need lights baked.
- What are the Best n Brightest Halogen Bulbs for Headlights
- Need help - Fog Lights for 2003 Civic LX
- Adding Overhead Spotlights
- integra running light problem
- 2005 Honda Accord Cluster bulbs q
- Can I use 35w hid 9006 light bulbs with 55w ballast?
- Severe lighting and electrical issues 94 integra RS
- Morimoto Projector Retrofit going in my cd5 accord
- What HID kit for my 2000 civic si
- Installation of ambient lights
- Eg foglight retrofit
- ek hatch needs help - lights are out
- Wiring diagram
- 2008 Honda Accord--location of Tail light Fuse(s)
- Completed my Morimoto Mini retrofit. Finally...
- Good brands ???
- 92-95 civic lx
- After installing HID car didn't start
- I got my HID Kit!
- 94 accord lights stopped working as soon as i tried wiring bumper lights to them!!!
- Paint on headlights
- Tail lights 2003 accord coupe not working
- 97 Accord Quality Projector...
- 2003 Accord headlights
- 91 CRX corner lights
- Intersection Light Installation for Ek. Help Needed
- 2001 Honda Accord Cluster Illumination Isn't Working
- Fog lights for 2000 Si
- 1994 Eg headlights/ fog lights
- 95civic fog lights
- H3 to H11 Foglight wiring harness?
- Civic type r headlight reflector
- Bought new "loose" headlights
- 95 Del Sol Headlights don't Work
- Reverse lights don't work correctly, 02 Accord
- Sending more power to HID ballasts a good idea?
- Installing headlight assemblies in 2007 Honda Odyssey
- 02 accord projector headlights not working, help!
- headlight polish
- EK Ebay fog lights upside down?
- Eg foglight question..donot want to run switch..?
- Need help
- need help..
- Wiring problems
- Xentec HID for the newbie
- Turn Signal Blinker not working
- I'm trying find the highest quality set of tail lights for my 1999 Civic EX sedan
- HID Kit for me?
- HID question
- Fog light lens reflector necessary?
- signals quit working
- Need Help Identifying these plugs
- Installing Fog Lights.
- Fog Lights
- 2000 civic lx dome light help
- EDM/UKDM Rear Fog Light Install Integra Help
- Need bulb # for 2000 honda civic map light
- My 96-98 retrofit
- 2013 Accord Headlights
- Need help with bulb receptacle connector
- Passenger Day running light not working
- Interior lighting.
- Right turn signal flasher/fast blink
- Retrofit using OEM EG headlights?
- Footwell lighting with domelight
- 1987 Honda Civic Indicator Relay Diagram
- Creamy white stuff inside my H4 plug
- 96-98 Ek Civic Headlights
- fog light swap (Lexus fog lights / EM2 Aero lip)
- anyone try the PWJDM Halogen bulbs?
- looking to replace headlights and front bumper light, dont know where to start.help?
- Aftermarket EF9 projector fog lights?
- 2013 Odyssey(Korean version) DRL Activation
- Dome Light
- Honda Civic Ek Led
- Headlight wiring harness
- Blinkers / hazard dont work
- which is the best plug and play hid brand?
- 96-00 Parts on 2001 Civic?
- High Beams Won't turn off!?!?!
- HIDS? Where to buy what to get?
- Esuse wiring layout/diagram?
- What kind of headlights are this??
- what brand of hids do i have
- hid ballast?
- Who makes these headlights?
- What's this kind of side door indicator's formal English name ?
- 06 accord turn signalsnotworking
- Fog Lights
- Why don't my tail lights work??
- Fuse tap
- H4H and R702K are they the same?
- integra jdm front end fog lights
- Flickering HID help
- Best plug and play HID kit? 2003 Civic EX
- 99 headlights on Eg help
- What headlights should I get?
- anyone used these headlights?
- Looking for help with trunk light wiring
- Aftermarket Fog lights install help
- Hella Optiflux Lights
- I want some ctr headlights!
- can some one help
- 94 Civic Stanley Fog light install help
- led interior lights
- lighting fogging
- Am I going to burn out my harness?
- fuses keep burning help??
- Fog lights not bright enough
- LED headlights retrofit
- HID problems... light strobing
- is this acceptable HID output?
- FS> T5 B8.5D 5050 1 (BLUE) LED cluster/instrumental Lights ?
- 1994 Honda Civic Help Needed
- Gutting headlights on an EG???
- need a little help...
- HELP EJ HATCH speedo and gas meter doesn't work!!!
- 98 civic turn signals won't work!!! HELP!
- DRL Help.
- HID Fog lights
- EG Ebay Fog Light Wires Burning
- need some help identifying projectors
- HID Lighting Question
- Indicator/Break Lights
- fog lights
- 1998 Accord turn signal won't turn off
- 94 accord
- 93 honda del sol dashlights and ac lights wont come on
- EG Interior Lights Help
- Using 9006 bulbs as 9005
- Need Help Identifying HID Kit
- 96 Civic hatch Headlights/Taillights not functioning
- 96ek headlights not working NOOB
- Instrument Cluster, Dome Light, License Plate LED Bulb Sizes
- 2007 cr-v interior lights
- Interior LED Opinions
- dc2 dash in eg running lights.
- 99 honda civic em1
- Need Radio Code for 2003 Honda Accord
- HID wire tuck problem
- The Retrofit Source HID Kits
- Crx/Civic Upper Belt Warning Lights Diagram
- JDM inspire fog lights
- anyone ever deal with Hidsrus.com?
- Fuses/Door Locks '94 Honda Civic 4 door
- Del Sol HID Aux Light
