PDA
View Full Version : Lighting
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13
  1. anyone have 99-00 civic fog templates?
  2. blinker issue?
  3. is there a write up in HID installation?
  4. Brighter Reverse Lights?
  5. H4 conversion to h4h videos on youtube!
  6. help please: 98 civic hb headlights
  7. Corner amber indicator light issue
  8. hid
  9. need help with shortage?
  10. PW:JDM headlight bulbs
  11. TL Hids /// retrofit?
  12. h7 retro fit question
  13. DIY: Clear Rear Turn Signal Bulbs
  14. need help with 97 accord se fog light wiring
  15. Need help asap
  16. Sylvania Silverstar?
  17. Jdm side markers wiring?
  18. NEED HELP / A6 Retrofit!!!
  19. 96/98 Civic Foglight Bulb size
  20. Angeleye Headlights!
  21. What side markers are these?
  22. HID interferes with radio reception?
  23. Retrofit HID ballast wire meltdown!
  24. Projector headlights with tsx lens?
  25. EF SiR retrofits??
  26. HID Questions on 09 Fit
  27. H4 HID Wiring help in EG
  28. Help with installing del sol fog lights...
  29. [EF9 SIR] RHD headlight instead of LHD
  30. infinity g35 H.I.D into dc
  31. Hid question with TYC headlight
  32. hid questions
  33. City Lights
  34. 94 accord audi conversion
  35. jdm integra headlight question
  36. Is there a Rear Fog Light for EK Sedan?
  37. lights dim to bright when
  38. 2003 Ex V-6 Fog lights shorting out Passenger Headlight?
  39. license plate lights??
  40. what are the easiest license plate lights to install?
  41. 9006 9005 Swap Failure, Bad Results
  42. how do i do this to my headlights
  43. LED brake light resistor?
  44. Ebay Foglights 99-00 civic sedan.
  45. fogs lights keep shorting out
  46. Guage lights
  47. leaking light help!!!!
  48. 92-95 EG Fog Lights
  49. INSTALLED HID KIT! only come on when high beams are on
  50. Questions about HID kit
  51. Question about hid ballast?
  52. pnp vs oem
  53. Light Bulb size? What size do i gotttt
  54. Wiring help
  55. Luminics VS HID
  56. Can I convert 2 wire led's to 3 wire?
  57. WHich wire is the parking lights?
  58. headlight tinting
  59. Source projectors from 2 driver's side headlights? Possible?
  60. RetroFit in ATL
  61. Best Bulbs?
  62. Turning signal help
  63. Would using HID's in this headlight be better than fluted glass?
  64. where can I get ballast covers / cases
  65. foglight harness help
  66. ...wetsanding your headlights...HELP!!!AHH!!
  67. which HID kit too get for car...so confused need help
  68. CTR / SIR / EK4 Headlight Wiring
  69. Help: Integra 4-door parts question!
  70. Bad ballast question.? THANKS!
  71. headlight goes out after a couple minutes. help??
  72. About Civic Fog light wiring harness??
  73. Driver side headlight not working (retrofit)
  74. 92eg dx hid vs 07 lx stock
  75. Crx lightning help
  76. Passenger side Bulb Housing Missing?
  77. digital hid 55watt vs 35 watt non digital
  78. LED's going out in gauge
  79. Fog light help!
  80. OEM sol lights suck - retrofit?
  81. Lady Driver! Question on EK Fog Lights!!! =)
  82. passenger side low beam headlight fuse keeps blowing
  83. Where to buy HID Retrofits
  84. Dc2 hid vs tsx hid Lottsss OF PIC 56K hang up!!!!
  85. Headlights
  86. amber corners to match oem markers
  87. Replacement bulbs for fog lights
  88. Anone ever use the 9005 or 9006 Led bulbs?
  89. hid kit bulbs different color??
  90. painting high beam bulbs...need help
  91. 98-01 Integra Retrofit?
  92. Auto Headlight 'on' for 94 Teg?
  93. HELP!! will rear lights from a 05 civic fit the 03 civic
  94. Question about HID color...
  95. what type of blulbs do the 2002 civic si use?
  96. BULB CAPS???
  97. 2008 Accord HID Projector Retrofit!!
  98. fog light question
  99. whats the difference between 9004 and 9007 HID bulbs
  100. McCulloch HID
  101. 93 Honda Accord
  102. issues with runnin lights
  103. HIDs in 94 OEM fogs??
  104. any upgrades to make side marker and rear brakelights brighter??
  105. How To Remove 2008 Accord Firewall .. Need Helps (want to change low beam)
  106. Apexcone 35W/55W Full Size Ballast HID kit
  107. WTB: 92-95 Civic Retrofit Headlights
  108. City Lights on my JDM front end
  109. Just a question!
  110. luminics vs silverstars vs toshiba HIR
  111. Hella Gen 3 LVQ-212 Replica Ballasts
  112. Anyone buy from HID Wholesaler at the top of this page?
  113. HELP!!! Does anyone know of a drl (daytime running light) KIT that will works on a integra? HELP!!!
  114. Issues with wiring OEM style eBay Fogs
  115. Please some advice. on these LED tail's integra.
  116. please help me (headlights for 98 civic coupe)
  117. Turn Signal Problems, Rear work, front nothing
  118. HID PROJECTOR HEADLIGHTS
  119. jdm headlights, with hid or hir?
  120. X3Racing (xtune) plug and play HID kit issues!
  121. Wire Hazards to Steering wheel buttons?
  122. Got my HID kit installed on the R1.
  123. pic request: piaa fog light bulbs
  124. Help Installing EDM/JDM Rear fog light on 96-00 Honda Civic
  125. 96-00 civic side marker installation
  126. Help with HID (new to forum and cars)
  127. question ??? headlights
  128. eg foglights
  129. What is the difference between these two Philips kits
  130. Projector lights
  131. Help with relay basics
  132. Help HID/ Headlights, This has got me stumped
  133. brightest, yellowest bulbs
  134. question ???
  135. Projector Headlights Help!!
  136. hey guys..my 98 Accord Ex headlights are to dim..how to brighten
  137. TYC black housing head lights HID kit - where to find ??
  138. Help No headlights!!!
  139. ?are the 1991 crx sir head lights the same as the regular crx?
  140. Third brake light not working
  141. What temp rating do these bulbs appear to be?
  142. 99 civic foglights
  143. DDM HID kits.
  144. Retrofitting a 07 TL projector into a 93 headlight.
  145. help hid's
  146. i really need help with this, my turn signal fuse keeps blowing... not sure why
  147. Headlight lens DESTRUCTION.. Replacement LENSES?
  148. Ebay si-vtec knock-off fogs for $120. Quality any good?
  149. Help help!!!! got problem w/ HID on a 08 Accord
  150. integra turn signal/parking lights question
  151. S2K HID shut off!!!!!!!!!!!
  152. one isnt working...
  153. H4H bulbs for jdm headlights
  154. 02 Accord V6 Fog Lights on with Brights Only??
  155. Starting a new HID site, need moderators!
  156. Anyone know the lumens output of different temp HID's?
  157. Cant find philips crystal vision bulbs
  158. possible i cooked my bulbs?
  159. DA9 hid question
  160. Spray tint help
  161. Depo clear fog light installation upgraded with HIDs.
  162. Just another Testing
  163. S2000 Projector cut-off wtf?
  164. just a test
  165. When break pedal is pressed instrument lights and corner lights come on too.
  166. retrofit hid's for 92-95 civic's
  167. Is there a "right" way to wire sidemarkers?
  168. Integra Turn Signal LED Bulbs 1157
  169. amber lights on eg cluster
  170. got h1 headlamps want to convert them to d2s.
  171. Fixing Dim Dome Light
  172. Fixing Flaking Tail Lamps
  173. Third Brake Light (CHMSL) LED Retrofit
  174. Day Time Running Lights
  175. brake light wont turn off on a DA
  176. DIY.....low beam bulb into fog lights
  177. foglight bulb for 96-98 civic
  178. SIGNAL/FOG/CORNERING LIGHT
  179. relay wiring, check my diagram
  180. d16 single cam go-cart
  181. Fog light loom install for 96-98 Civic
  182. HID retro DIY?
  183. LED Bolt Question
  184. 07 Accord
  185. HID's
  186. lens paint has anyone used it?
  187. HID FOG Light Flicker
  188. Cluster Light bulbs
  189. 1989 Honda Hawk lighting problems..?
  190. JDM Cluster ?
  191. HID question, I SEARCHED!!!!
  192. Park & tail & dash light problem in one
  193. DC Corner Lights - Where can I get wires/bulbs?
  194. having some wild lighting probs.
  195. shiftlight?
  196. Difference between H4Sk to 9006?
  197. Dash bulb burned out. A few questions
  198. HID flicker, what causes it?
  199. H3 3000K foglights acting up
  200. H3 3000K foglights acting up
  201. Start of 00 Civic Retro with Murano Clear lens :)
  202. H4 HID kit plug-and-play on an EF?
  203. head light wanted
  204. adjust the headlights on integra?
  205. jdm foglight install help
  206. 97 civic headlight apps.
  207. headlight setting on dash
  208. hids EF's
  209. Need a some HID Advice
  210. gauges autometers
  211. how to pull apart headlight thread?
  212. Gear indicator light on '96 Civic - availability
  213. ctr headlights dimming. help.
  214. hid help PNP ebays. yes i know
  215. Where to buy Xenons
  216. anyone have info. on putting tsx hid's into jdm type r non hid lights
  217. H.I.D. Help
  218. just installed hids. need help!
  219. Guide on how to tint 94 del sol tail lights
  220. how can i make my corner light real amber???
  221. Who has HID highbeams? Pictures please!
  222. DA 1piece headlight foglight help!!!
  223. Replacement fog light bulbs
  224. Corner park lights
  225. 98-02 honda accord headlights 4 sale
  226. New to HID's please help
  227. 99 Civic Projector Headlights
  228. Fog Lights, Headunit, and Dash light NOT WOrking!?
  229. So.. foglights.
  230. HID XENON KIT 6000k
  231. looking for H4H HID bulb
  232. What size HID bulbs would fit in my car?
  233. 9006 to D2R adapter shroud.
  234. H4H/L bulb
  235. Confused about HID wiring.
  236. I need some direction (TSX HID RETRO on 94-97 DC)
  237. prelude retro fit ??
  238. Daylight Running Lights ONLY - Main Headlight is NOT Working
  239. HID Wattage Difference
  240. integra 94-97 fog light suggestions please~!
  241. Mercedes E Class W211 HID
  242. help with ek foglights/fuse panel
  243. whats the best h4h halogen bulbs?
  244. Need relay kit for HID kit?
  245. hid kit
  246. LED Tail lights
  247. hid help
  248. fog light help
  249. Serious problem with tail light; Nobody can find the short
  250. i need help asap integras!!!!!!1
