Lighting HID/Xenon kits, Retrofits and Associated Topics
Which HID System?
Old Sep 10, 2007 | 03:13 PM
C_Rock77's Avatar
Default Which HID System?
I bought a DC2 with a Retrofitted BMW HID system. However, one of the ballasts is completely out (and he threw a halogen bulb in the housing b/c he got a ticket). The other HID has issues.....it acts like it tries to fire up, but only flickers. You have to click it quite a few times for it to fire.
Should I just get a PnP kit and put it in the retro'd headlights? The newer kits that are out there that have a harness included.....what do they connect to? Do you plug them into the headlight harness?
What would you guys suggest?
Old Sep 10, 2007 | 05:12 PM
Padawan's Avatar
Darth ModerVader
Default Re: Which HID System? (C_Rock77)
You can find replacement D2S capsules and ballasts at places like HID Planet. You really don't need or want a "PnP kit", since your setup is running actual OEM HID projectors already.
I may, however, be misunderstanding what you mean by "retrofitted BMW HID system", since you do mention that he put a halogen bulb in one of the housings as a temporary solution. If you're running the stock halogen projectors, then you will indeed need a kit that features 9006 based HID capsules.
Old Sep 10, 2007 | 07:27 PM
C_Rock77's Avatar
Default Re: Which HID System? (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">
I may, however, be misunderstanding what you mean by "retrofitted BMW HID system", since you do mention that he put a halogen bulb in one of the housings as a temporary solution. If you're running the stock halogen projectors, then you will indeed need a kit that features 9006 based HID capsules. </TD></TR></TABLE>
The headlights have retrofitted HID projectors. It HAD ballasts, capsules, & projectors from a BMW 5 series. He was driving the car w/ one of the ballasts blown, and got a ticket. So, he stuck a halogen bulb in the housing to have some kind of illumination to avoid getting another ticket. What is confusing? I did not install the system, so, I am not understanding the confusion.
Old Sep 10, 2007 | 07:35 PM
Padawan's Avatar
Darth ModerVader
It confused me because you mentioned the halogen bulb, and at times, people mistakenly use the term retrofit to instead mean simply finding a way to modify stock D2S capsules to fit the halogen projector housings.
Now that it's clear what you have, then a good solution would be to order replacement parts from somewhere like HID Planet. You may also want to double-check the wiring to ensure that it was done properly.
Old Sep 12, 2007 | 04:55 PM
Genuine Rolla's Avatar
The easiest way to go about this bro is just get PnP D2S HID kit.
Old Sep 18, 2007 | 08:01 PM
Mfoehrkolb's Avatar
NEVER GET PNP kits, just do it right and do a good retrofit. your a hazard to us all with pnp in cars.
http://www.HIDplanet.com
Old Sep 18, 2007 | 08:03 PM
Mfoehrkolb's Avatar
im buying Hella Gen3 Ballast, TSX Clear lense projectors, and a custom wireing harness. its FTW.
Old Sep 19, 2007 | 05:32 AM
devani's Avatar
does it have a wire harness??
change the bulbs from left to right...make sure both bulbs are worknig...
if they do work and have a wire harness....then get one ballast from ebay...single ballast should be less than $100..
Declectic
Honda Civic (2006 - 2015)
14
Aug 23, 2006 03:42 PM
matt21civ
Honda Civic (2001 - 2005)
Jul 24, 2006 05:29 AM
vdub08
Jan 1, 2006 11:21 PM
xyooj
Jun 11, 2005 06:24 AM
user 996328629
Feb 17, 2003 02:25 PM
