PDA
View Full Version : Lighting
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13
  1. 99' EJ8 HID fog advice
  2. Harbor Freight Fog light Bulb type???
  3. 9000k hid bulb?
  4. Marker Lights
  5. lighting question
  6. Got ripped of by Xentec..
  7. Phillips X-treme Power vs Sylvania Silverstar
  8. wiring 5-pin oem fog switch?
  9. Replacement projector dome glass for oem eg9 foglights
  10. Civic EK projectors
  11. HID/ Projector Questions??
  12. Lazy eyes/Winker kits?
  13. Kydo 9005 HID
  14. best lighting non-hid
  15. Acura RSX LED Dome Light Upgrade
  16. Osram Nightbreakers, phillips crystal vision ultra, or phillips x-treme power?
  17. Reverse Light Diagram
  18. Fog Light Retro gone wrong!!
  19. hid question
  20. Has anyone done the 9006 to 9005 conversion ?
  21. h4/hb2 pigtail to 98 honda prelude
  22. foglight wiring question
  23. LED Dome Light for 96 civic?
  24. Whole Rear Driver Side Lights Won't Turn On
  25. Corner lights matching silverstar ultra 4100k?
  26. Fogs for a Del Sol
  27. HID retrofit on EK
  28. replacing projector bulb
  29. Having major lighting issues and need help.
  30. HIDs for my 96-98 ek fogs
  31. Im not sure what kind of light i have..help please! honda doesnt have it
  32. Denji headlamps
  33. Honda Odyssey LED Dome Light Kit
  34. Esuse Fog Lights?
  35. Attn: EK Lighting Experts
  36. Lighting experts need your advice
  37. civic sir headlights
  38. Headlight restore/HID question
  39. My lights > yours
  40. Issue with Passenger side HID..
  41. Thinking about HID's
  42. 100W bulbs in esuse fog lights?
  43. headlight retrofit needed done
  44. WTB: D1S hid kit
  45. Thinking of doing an HID retrofit looking for so advice
  46. Rear Amber Install
  47. brightest/whitest 9005/9006
  48. Hid hi beams... Drl problems
  49. Aftermarket HID's in non-projector headlights
  50. What type of headlight is this?
  51. Should I go HID?
  52. 93 civic si interior light problem
  53. JDM Front end Conversion EF Help !!!!!!
  54. Signal switch problem. please help me
  55. What are some good HID namebrands?
  56. integra sidemarker wiring
  57. Xtreme HID Ballast
  58. Got a Relay harness for HID..
  59. Fog bulbs and low beams
  60. 00 integra halo lights
  61. WTB HID NOT MADE IN CHINA!
  62. Neons or the equivalent
  63. Fogs on a 99 GSR with a frontmount?
  64. Aftermarket headlight bulbs
  65. honda accord body kit turn signals
  66. HIDs....dead battery
  67. jdm fogs
  68. Can You Use a 55 Watt Ballast with 35 Watt Bulbs?
  69. HID install problem
  70. HID install, 1 headlight not working 96 civic.
  71. HID Help: HID's start to light up then shut off...
  72. Mcculloch hids ignite problem>>>>>? help
  73. EG Fog Lights bulb replacement
  74. No brake lights need help
  75. Double Filament Wedge Bulbs?
  76. Converting H3 housing to use H4 bulbs..??
  77. parking city lights/bulb sizes jdm front
  78. 92 EG 4 door taillights
  79. Which fuse
  80. 2008 Accord Coupe HID install
  81. Attempting to refit all lights
  82. Replica CTR headlights?
  83. Was given an HID kit, what else do I need?
  84. DIY: Lexus Yellow Capsules on Civic EG
  85. RetroFit headlights? Civic EG
  86. Clear Headlight Film?
  87. 3M Headlight Cleaning Kit
  88. 9004/HB1 for what Car Model?
  89. LED Website?
  90. flickering light
  91. LED 194
  92. Integra projector 94-97 vs. 98-01
  93. 99-00 Ek Foglights cracked question / HID's
  94. rear lights wont go on???
  95. Changing color of gauge cluster, how many bulbs?
  96. After market Retro fit......
  97. 09 4 door si retro
  98. tech1hid legit?
  99. fog lights with no harness
  100. fog light help
  101. LED shift bar?!
  102. EF HID Retrofit options. Need suggestions.
  103. Fluted lenses (with pics)
  104. del sol projection ?
  105. del sol fog light. plz help
  106. Fog light bulbs won't come out.
  107. Bi-xenon projector HID CONVERSION
  108. del sol light adjustment
  109. Right DEPO fog light on 99 ek keeps burning out
  110. looking to upgrade to hid but still a lil confused could use ur advice
  111. Ek Side Markers (help me!)
  112. Need serious help! Looking for rare part!
  113. EG rear fog light for $2
  114. [HELP]99-00 ek ebay fog light wiring problem.
  115. Ex hid kit for my ej1
  116. need some help!
  117. Light problems, light scatters...
  118. 2007 Civic Coupe - Fog Lights/DRL's w/out parking lights
  119. Still confused about HID for 94 Integra
  120. OEM Raybrig 99-00 Foglights fuse problem...Need Your Help!
  121. da fog lights
  122. LED undercar??
  123. fog lights
  124. Help o turn signals ?????
  125. Wireing interior light .. HELP !!!!!!1
  126. Dull lighting
  127. Retrofit Wiring Harness
  128. EG Side Marker and Turn Signals
  129. LED vs. Chrome (corner bulbs)
  130. Foglight film advice
  131. Help.Gear Position Indicator Question
  132. xenon bulbs only?
  133. Best Ballast locations for '94 thru '97 Accords?
  134. YELLOW HIDS?!?!?!
  135. HID in Fogs
  136. ek fogs in 300c
  137. EG foglight harness work for dc2 foglights??
  138. no turn signals????
  139. ]Halo Light in HID?
  140. led blinker lights. help pleaseeeee
  141. are these real denjis?
  142. What HID
  143. eg foglights???
  144. HID bulb replacement
  145. Wiring My Duckbill
  146. 00 Si Headlights
  147. Hid Kits!?
  148. Modding my Horn Button
  149. Left low beam out in EM1
  150. how do I hook up a toggle switch and LED
  151. Is Single Sided Fog Light Illegal?
  152. Difference between Bi and regular hid lights? HELP CUZ IM BUYING ASAP
  153. HID wont turn on, Need some advice
  154. HID retrofit.... I think I got my ballasts wet....
  155. BRAKE LIGHTS stay ON? need help.
  156. 98-01 DC Fogs
  157. Wiring Problem with headlights.99 Integra
  158. DA JDM lights HELP BULBS DONT FIT
  159. sidemarkers db8..
  160. denji headlights
  161. Converting OEM D2R HID to Non-HID??
  162. 100watt h1 in projector
  163. Can I put brighter light bulbs in my stock housings?
  164. HID PROBLEM
  165. How hard to install sidemarkers? EK civic
  166. Yellow High Beams on 99 GSR Integra
  167. Identifying HIDs and harness ?'s
  168. password jdm bulbs?
  169. Dash Lights Burned Out!
  170. signals and hazards dont work :(???
  171. Help! Burnt ballast!
  172. Colored 1156 or 1157 Bulbs?
  173. Brake lamp failure sensor troubleshooting
  174. Anyone Bought HID Kits From Here?
  175. Do Slim Ballasts Have More Problems Than Regular Ballasts?
  176. Foglight trouble
  177. 96 civic with 99-00 front end foglight wire q
  178. OEM Headlight Question
  179. Angel Eye Wiring
  180. Altezza Tail Light Question??
  181. dc5 sidemarker
  182. Apexcone 6,000 HID Kit
  183. Fog wiring
  184. How Do I wire front signal to rear signal
  185. HELP!!! please. Delsol head/aux-lights stop working
  186. head light not working
  187. eg6 headlights hid?
  188. Bad Ballast Causing Running Lights to Not Turn On?
  189. I want all clear headlights... Help
  190. '91 civic w/jdm front wiring help
  191. k-light hids
  192. 1999 Honda Civic Headlight ideas needed
  193. tyc projector headlights with HID's. any good?
  194. Side Repeaters - positioning lights
  195. S2000 side markers
  196. help with amber dash lights
  197. HID High Beam Wire Up
  198. Headlight Bulb size guide 97+
  199. need help on my foglight install..
  200. ouch bright lights
  201. head liight and tail light blink fast?
  202. Laminate or UV coat plastic headlights?
  203. can anybody give me a hand a min?
  204. HID Kit Problem
  205. 94 civic diy halos
  206. Where can i find the jdm headlight sockets for a 1991 civic ef????
  207. trying to find 3rd brake light
  208. Vans Yellow Fog Spray
  209. HAS ANYONE TRIED THE DDMTUNING HID KITS?
  210. hid ballast quick question
  211. 96-98 civic foglight wiring HELPP!! =[
  212. amber cd player
  213. HID upgrade questions
  214. Chinese Domestic Market Parts
  215. how to make a new line in fusebox
  216. HID retro in JDM non-HID headlight
  217. Directed 545T Nite Lite wiring help
  218. 96-98 jdm square fogs
  219. HID's for 95 Sol
  220. parking lights don't turn off!!
  221. Help identifying side markers
  222. how to dim down high beam?
  223. Parts list for my HID retrofit
  224. STOCK EG HEADLIGHTS UP FOR SALE
  225. 1999 honda accord headlight problem
  226. EG6 retrofit
  227. need advice for amber dash lights
  228. question about stanley 4043
  229. How bad is this glare
  230. sidemarker measurement
  231. DA headlight Wiring, How do I get it Like this pic...
  232. climate control lighting
  233. I'd like to turn my foglights into turn signals. LOL. Gurus enter.
  234. are these projectors? + ?'s about front end [dc4]
  235. Taillights do not turn on when I turn headlights on... but all other lights work!
  236. EDM civic headlights
  237. Picture Request EK Square foglight in EF bumper
  238. SC430 projectors, ballast and bulbs (S.FLA)
  239. Fog lights keeps burning out
  240. Good Headlights Bulbs
  241. Rear Lights don't flash when I break?!
  242. autometer guages dimming
  243. Lighting Problem
  244. NEED HELP!! EG brake lights are not working....ideas??
  245. wiring prob..
  246. 95 ex coupe headlight not working
  247. Selective Yellow Headlamps, Where to buy
  248. Lighting Questions
  249. Okay guys I think I finally found an LED turn signal bulb!
  250. 95 integra fog light wiring
