View Full Version : Lighting
Pages :
5]
11
12
13
- yellow foglights
- lighting problem!!!
- Integra HID retrofit How to
- HID Retrofit links
- Headlight Lens Repair Question
- 1990 Integra LS headlight issue!
- corner light problems
- Looking for ideas for a projector fit in a 95 civic
- my hazard lights wont work! im sooo frustrated
- HELP - 99-00 CTR Headlights and HID's
- EG hatch brake lights not working!! please help!
- 90-93 Integra Headlight Harness Adapter?
- taillight blinkers
- Hey guys need some help with my taillights
- Aftermarket Gauges - Indiglo, APC, OBX, eBay
- Flickering HID lights vs. Solid HID kits
- 99 accord coupe pnp headlights???
- 96 accord headlights whats best
- 96-98 fog light install help OEM stanleys & PW:JDM OEM wiring kit.
- which hid color temp has the most lumens?
- HID's different colors?
- password jdm foglights help!
- 92-95 Civic Lighting Issues
- bye bye yellow lights
- 95 eg turm signals
- New headlights
- EG foglights blowing fuse!?
- DC2 Integra fender sidemarker location
- hid driving lights
- TYC one piece headlight high beam brightness
- fog light wires smoking help please
- HELP: 99-00 Civic Coupe DEPO Foglights
- Lights flickering
- help hids too bright i need a shield
- Lights Flickering
- Dimmer does not work
- FS: Xentec HID Kit 8K H7 bulbs BRAND NEW
- Guage Cluster
- Interior LEDs
- Want To know how to rewired
- Civic 2010 bulbs
- help XenTec 10K HID Kit only one light dont work side blow fluse.
- additional relay harness for HIDs on older vehicles???
- help XenTec 10K HID Kit only one side blow fluse.
- jdm eg6 sir runing lights dont work!!! help
- Passenger side light went out again (only a few weeks after replacement bulb)
- H8 bulb - Los Angeles area
- 95 accord front bumper blinkers
- Hella
- Crv ignition ring light retrofit in ek?
- jdm headlights
- marker light in fender molding???
- LED problems.
- With too many choices out there, which HID kit should i buy?!
- 55w HIDS
- Cruise control switch for fog wiring???
- Just installed HID but they are angled off.
- Interior Lighting
- Sonar projectors 92-95 civic bulbs
- 3,000k? in my fogs?
- Hid retrofit: does the light output look right?
- Civic EK retrofit.
- 2002 ep3 type r headlights? help??
- Any headlights besides CTRs have city lights?
- Is hidsrus a legitimate company...?
- 2003 Accord fog lights
- passenger low/high beam not working????
- what size led is this?
- s2000 retrofit parts help
- .Are these good $40 fog lights? 99-00 civic
- D2S bulb in D1S Projector
- DC Sidemarkers on DA..Need Templete
- HELP with 99-00 Fog Light Install
- does anyone have these headlights???????
- 08 Civic Si Fog Light Install Help
- Headlight Problems
- What is the best option for yellow bulbs?
- help!!
- Need help Re-wiring my headlights and bumper lights help ASAP!!
- How to install HIDs in my 00 Civic?
- Good lighting cheap
- 2010 civic - Accesory power for internal floor illumination
- What headlight bulbs should I get for my EG?
- headlight not working after AC removal
- Need Help With Bumper Blinker Lights On 88-91 Civic
- brake light help?
- DDM Tuning HID Kits
- Help with removing XENON HID KIT
- 04 Accord Deck lid light
- got a ? about McCULLOCH HID kits
- HID Problem Flicker
- hid problems
- HID'S
- Front Signal Lights Don't Work
- 2003 Honda Civic Light Problem
- Brake lights are on all the time!
- '01 Civic HID Help!?
- what is this wiring? 99 civic ex tail lights. pictures
- Questions about aftermarket headlights
- Question about headlamp lighting...
- turn signal problems
- dash lighting
- Moisture/water build up in headlights
- HID Light bulbs
- 96 ctr headlight
- Having trouble with jdm ej1 fog lights!! NEED HELP!!
- PIAA H3 Ion Crystal or Amber H3 LED?
- What are the brightest, most yellow foglight bulbs?
- what is best?
- SHOW ME
- Halo Projector lights
- Head light problem
- Proper Wire Gauge
- question about l.e.d. lights
- hid strobe lights
- Is there any way to install HID into EG fog lights?
- headlight coloring video
- Where can I find HID lamps that are rebased for 9006 and 9005 applications?
- Headlight Hookup
- Weird HID issue on 04 Civic.
- fogs for 96-97 del sol
- Ek Si Fogs installed on a EG??
- EP3 Leveling System Wiring
- HID and High Beam
- Anyone have issues with 9006 DDM tuning bulbs?
- Thanks H-T. Saved me $50 of ugliness
- Front parking light stopped working after HID install, help
- what is the type of blub in an eg fog light
- Honda Pilot Marker Lights
- Lime Green Foglights? Film or Colored-Bulb?
- 2000 civic ex fog light adjustment
- foglight ?
- Will the 94-97 Foglights fit 98-01?
- NEW TOPIC: Rear Integra FOG LIGHT Template
- HELP.. my headlight wires are ****ed..
- FOGS. Is it Possible?
- I want to know which is best?
- Which hid kit Temperature gives you BLUE
- HID's with daytime running lights?
- DDM Tuning
- Dash and CC lighting, My experience/New info!
- 99 civic si headlight problems
- One headlight brighter than other
- Best headlight bulbs
- turn signal flasher
- Im not sure
- Too many things hooked up to a fuse?
- 08v31-s01-10007 VS. 08v31-s01-10107 Help
- Civic headlight wiering.
- HELP!
- HELP ON HID's THAT CHANGE COLORS
- JDM one piece Fog light wiring problem on DA
- help with high/low beams
- low beams wont work
- Park lights not working one headlight burns dim
- Will this work in my car?
- Bumper light/Corner light/Fender light
- gauge help
- How to make gauge needles glow white?
- Foglights stay on with ignition
- corner lights, tail lights, and fog lights help
- 98 civic dash lights
- HID retrofit projector question...
- 2000 Si cluster needle light not on...
- Anyone on the Forums do Retrofit's?
- adjusting the cut off line on itr one piece projector headlights??
- JDM corner repair..Help
- integra da light questiion
- PnP hid bulbs to use with retrofit?
- 90 civic turn signal problem
- HID problema
- integra headlights - unknown projector
- McCulloch HID ballast pinout?
- LED headlight info
- Fog Lights Stuck in Customs
- Turn signal light not working
- 99-00 Dome/ interrior lights
- Bi Xenon HID kit PnP with projectors (Dead Horse)
- hi/lo hid kit in 93 eg problem
- 2 hid kits in 1 car?????
- HID foglights into EJ8
- WIRING BUMPER LIGHTS
- noob question..dash lights
- hid projectors
- RED turn signals to blink AMBER
- What color?
- High tech HID?
- HID High Beam Issue
- JDM ITR Retrofitted into EG6 headlights
- oem rear fog light wires
- 25w HID?
- Gauge Cluster and parking lights also taillight problem
- Is it just me or is my cutoff jacked up?
- Ebay 92-95 4dr OE Fogs Credibility?
- Retrofit, Which way to go?
- HID Light question
- Help with HID
- LED bulbs
- Just installed hid kit, FM reception affected
- LuminicsUsa Bulbs?
- custom DA headlight
- what kind of lights are these? HELP.
- Denji Headlights
- fog light help
- Atoning for our sins
- My 9006 HID's....HELP!!
- sidemarker wiring
- Problem with HID kit
- 10000K HID Legal in Illinois??
- help with EG foglights
- wiring fog lights on my 91 teg.
- can tints be used to smoke taillights?
- New Ebay Headlights for Eg comment
- NEED! 92 Integra headlight socket wiring!
- sunpro guages/oclored bulbs
- How do I tell if HID buld is bad??
- Need another Solution for HID
- TSX retrofit into 92' prelude JDM black housings!! (56k die)
- really weird.....
- ELECTRICAL PROBLEM???? BRAKE LIGHTS DONT LIGHT UP
- 03 tl hid help
- Want to slow down my turn signals
- Clear lens mod dc4
- Hid Problem in a DC4
- HID problems please help
- Lumen Rating
- any write-up for cluster lighting ??
- Stock HID turned pink
- Where to buy projector housings
- Wiring LED Rear Backup and Fog Lights
- 09 honda civic headlights
- Lengthing wires between ballast and bulbs???
- usdm fogs jdm harness
- OEM Retrofit Vs. Aftermarket Retrofit
- Most OEM like headlight sealant?
- *Retro-Solutions Brand HID products: Y or N?*
- city lights help
- headlight problem 91 accord
- HID'S
- head lights and tail lights
- 98 civic ex dome light
- city light question
- My lights don't...light
- What would i need to retrofit?
- Need some answers answered?
- HID problems
- fog light help
- Xenon Depot Xtreme HID Kit on 08 Civic
- MAX Lighting..
- Halo Projecters, what i need?
