Classic Hondas All Pre-1988 Hondas.
1987 Civic 1.5 SI bouncing RPMs on warmup?
Old 01-15-2011, 03:38 PM
paatchen's Avatar
Default 1987 Civic 1.5 SI bouncing RPMs on warmup?
When I start my car to let it warm up, it starts up great and revs up to about 1800-2000 RPMS when the engine is cold.
Once the engine warms up a bit and the therm needle gets just over the C (cold) indicator, the RPMs start to come down from 1800 to 1500. Then it starts to bounce the RPMs from 1500 to 500 to 1500 to 500. It is like I am pumping the gas.
Once the engine gets warm to running temp, it does not do it anymore for the rest of the drive, unless the engine has a chance to cool down again.
Any help on how to fix this will be awesome. Thanks so much.
~Toph
Old 01-17-2011, 12:59 AM
NW Classic Honda's Avatar
Default Re: 1987 Civic 1.5 SI bouncing RPMs on warmup?
Mine does the same thing. lol Iv tried to fix it but no luck.
Old 01-22-2011, 05:49 AM
anjin's Avatar
Commonly air in the idle control valve on the back of the throttle body. You have water piping from the head across to the bottom of the throttle body, up to the idle control valve, and back to the engine. Could be a simple air bubble which some bleeding of coolant can fix, or it could be a blockage in the pipe under the throttle body or into the idle control valve. I've had both - but the first is much more likely.
BobLoblaw
07-20-2019 09:11 AM
hondacivic97si
15
03-11-2015 10:23 AM
the0ne
12-13-2004 01:02 PM
LiL accORd RideR
10-09-2004 10:48 AM
Quick Reply: 1987 Civic 1.5 SI bouncing RPMs on warmup?
