86 civic O2 sensor
86 civic O2 sensor recommendation
For a 1500 carb engine with 140Kmiles, is there a good O2 sensor for the money, between the $40 bosch and the $300 Honda ... What have you used.
I failed smog due to very high NOx.... the lambda is on the lean side, the EGR is working as specs.
Check my post on this site
http://www.artsautomotive.com/forums/topic?id=2351
Thank you
Thank you
Re: 86 civic O2 sensor
Thank you for the recommendation, I had to settle for the $20 bosch universal as the connector does not fit my set up, apparently the designer did not pick up the right gender..... so the perfect fit has the same connector as the one remaining in the vehicle.
Smog test tomorrow.
Smog test tomorrow.
