Classic Hondas All Pre-1988 Hondas.
87 civic problems.
Old Apr 9, 2011 | 02:22 PM
smokenyall's Avatar
Default 87 civic problems.
ok my grandpas 87 civic runs and idles fine. you can basically floor it threw 1st and 2nd but at freeway speeds you have to baby the throttle because if you give it too much the car actually slows down. so what can be causing this. about 9 months ago i replaced the head gasket, cap and rotor, plugs and wires. if anybody can help please help .
Old Apr 11, 2011 | 08:04 AM
letank's Avatar
Default Re: 87 civic problems.
Carb or efi?
from the easier to the more $
Pinch the egr hose
Which spark plugs, I had issues years ago when we installed some cross reference spark plugs it could not go over some steep hills.
Old Apr 12, 2011 | 01:53 PM
smokenyall's Avatar
it has a carb and a million vacuum lines. and im quite sure the plugs are ngk but i dont know the heat range. the car started doing this recently.
Old Apr 18, 2011 | 01:56 PM
letank's Avatar
The carb has a million and half mile of hoses.
Start with the simple things
Replace both fuel filters, the rear one by the driver's side rear wheel and the one by the valve cover. The rear one can be a pain, the cross reference one from Fram that I got was not exactly the right size to fit in the bracket, I spent half an hour to hack the bracket. Check w honda if they still have the rear fuel filter.
TexasCheddar
Oct 14, 2013 02:53 PM
narab123
Honda Civic (2001 - 2005)
Oct 1, 2012 11:30 AM
lilmisshonda
Jun 30, 2008 09:49 PM
korndog
Feb 25, 2005 02:24 PM
krazn
12
Nov 22, 2002 08:36 PM
