PDA
View Full Version : Honda Fit
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13
  1. 2013 Car having trouble starting in cold weather
  2. Dual clutch or CVT
  3. 2010 Honda Fit Electrical Issue with Passenger Headlight/Running Light/Blinkers
  4. Lizard died in front windshield defroster vent. Help please :(
  5. Fit GP5 Dual Clutch
  6. Honad Fit clutch hard on the knees?
  7. 3rd gen short shifter?
  8. Unsure about knocking sound front left tire
  9. 2019 Honda Fit TPMS Light Reset
  10. Fit 2009 failing to start
  11. scanner wont connect to ecu after rainy day and key started flashing too
  12. SRS on at hiway speed
  13. 2007 fit loose key in ignition
  14. '13 Fit fuel relay problem
  15. 2007 Honda Fit Sport Head Gasket Issue?
  16. Honda Fit Jerk -CKP Sensor P0339
  17. 08 Fit Sport Flickering Instrument Cluster
  18. Adding cruise
  19. Looking for 2017+ Fit, sway development
  20. 2000 Honda Logo SRS components
  21. Heater / AC Blower Question
  22. 2011 fit throttle control relay location
  23. 2010 Fit Sport horn, brake lights and cruise problem
  24. Replacement Maser Cylinders for Honda Fit
  25. Navi ststem upgrade
  26. Advice needed..Rear wheel liner removal
  27. Water in spare tire compartment
  28. 08 Fit Sport A/C doesn’t turn on
  29. 2009 Honda Fit - O2 sensor Bank 1 Sensor2
  30. DTC Trouble Code Meaning
  31. Normal discontinuity at seam of dash moulding?
  32. Weird noise on decelerating when stopped
  33. Considering getting a Fit but i have a few questions.
  34. 2013 Fit - Hard to stop
  35. What onstitutes gentle RPMs in the winter?
  36. Poor miles per gallon
  37. Full Size Spare Wheel - Will it Fit?
  38. Bulb replacement
  39. Depleted Honda Fit battery -- how long to recharge, how to re-enable radio?
  40. 2017 Fit Shaking on speed 40+mph
  41. Honda Jazz GK 2017 5" Radio backup camera install
  42. How to determine if mirrors on Honda Fit are being heated?
  43. 09 Fit Transmission Fluid low and foaming
  44. 2018 Honda Fit Tire Pressure Sensor issue
  45. Stumped with electrical issues
  46. Wheel alignment question
  47. Tries to shift when at a stop.
  48. Hand brake freezes and defroster seems nonfunctional after flood remediation
  49. Honda Jazz ABS/Bearing Problems
  50. Brake line freezes during first winter snow after flooding
  51. can't get into car
  52. my fit doesnt drive above 20km/h
  53. Ge8 front lower control arms question
  54. Where can I locate the front impact sensor as well as the enviroment temp. sensor?
  55. Troubleshooting Code P0302 - Any Spark Plug How-tos
  56. 2015 Honda fit is slow as hell
  57. Honda Fit Pedal Size
  58. Heater Control Bulb Replacement
  59. honda fit ig fuse keeps blowing
  60. Flash drive formatting
  61. which fuse runs the alternator on 2007 honda fit
  62. Headlight Indicator Light Issue
  63. Best engine and transmission swap?
  64. Dashboard warning lights blink while driving
  65. Green Key blinking
  66. Coolant for Honda Fit 2015
  67. Honda 2011 Fit. A C doesn’t work on long trips
  68. Getting some fuel from the pump
  69. my used 2013 honda fit remote entry doesnt work
  70. "Best" windshield shade for Honda Fit 2013?
  71. Ice and snow in front suspension (2010 Fit Sport)
  72. 6904-A1 code displayed on speedometer?
  73. New to Honda & Fit
  74. Coolant temperature sensor
  75. valves clearance honda fit 2013
  76. 2015 Honda Fit fuel leaking into oil
  77. compatible obd2 devices
  78. Rivet/eyelet for cargo cover, Honda Fit 2013
  79. Push button issues with 2015 Honda Fit
  80. ABS 15-19 and 12-17
  81. Car won’t move
  82. RPM dropps
  83. 2018 Fit: will ECU advance spark if I burn 93?
  84. Honda Brakes
  85. Starting sometimes
  86. 08 Fit low beam trouble shoot
  87. 2015 Honda Fit Defective Paint & battery
  88. 2015 Honda Fit VVT rattle on cold start-up
  89. we had the a/c check, filters changed, recharged, and it cools great.
  90. 2010 Fit throwing code P0138
  91. Talk me out of buying a 09 fit with 300k miles
  92. P0369 & P0339 sputter and hesitation
  93. Windshield
  94. Moulding near trunk gasket is lifting
  95. HONDA FIT 2017
  96. Troubleshooting: '05 Fit - Power loss and hesitation during normal driving
  97. srs light
  98. Disconnecting intake pipe from throttle body
  99. bumper compatibility
  100. Any Honda Fit 2010/later *not* have a pouch behind front passenger seat?
  101. Oil Filter
  102. 2009 Fit stumbles and (apparently) misfires ... bad PCM?
  103. What is this hose?
  104. Can't transfer iphone contacts.
  105. Acceleration Problem
  106. "engine replacement"
  107. Honda Fit Aria CVT Transmission
  108. abs fault help 2002 jazz 1.4
  109. Drive Cycle
  110. 2008 Fit rear spoiler to 2010
  111. honda fit idsi 2004 judder
  112. 2015 Honda Fit doesn't start
  113. Honda fit yellow message display screen
  114. 2008 Honda Fit
  115. 2008 fit sport, AC, nothing happens
  116. gd1 not fit
  117. headlights
  118. FUEL CAP MESSAGE ON DASH BOARD
  119. OBD2 engine coolant temp reading on 2018 FIT EX
  120. Car flooding: Speculative diagnosis & remedial measures?
  121. 07 Fit P2646
  122. Honda Fit Door Compatibilty
  123. Honda Fit ECU - Help to identify
  124. Air bag light
  125. Purpose of Metal Loop welded to Gas Tank
  126. Assembly plant marked with X
  127. 2010 jazz roof moulding
  128. honda fit 08 not starting in cold weather
  129. Does road salt cause rust in engine compartment?
  130. Cylinder head compatibility
  131. stuck automatic key lock
  132. my 2007 honda fit is reading negative 15%
  133. headlight assembly removal
  134. Honda Fit door lock cylinder woes
  135. Cruise Main Light
  136. Power Window Issue
  137. 2008 Honda Fit and highway noise.
  138. 2007 honda fit headlight reminder chime not working
  139. Lug nut issue
  140. Timing Chain or Timing Belt?
  141. timing belt or chain
  142. 2018 Fit LX Price
  143. Rail Dust on my first ever Honda and brand new off the lot
  144. HDMI location for jazz
  145. Honda Fit Engine Swap
  146. Hi,
  147. choosing a roof rack for a 2012 honda fit
  148. 2008 fit timing chain re-position
  149. Honda Jazz 2013 UK rear calliper bolts sizes
  150. honda2008 fit engine; what other car will it fit in?
  151. Spark plug blew out of head.
  152. P0420
  153. Climate Control Blowing Hot
  154. Key can be removed while driving ?!
  155. 2003 FIT with tranny issues after flood
  156. Radio on after ignition off
  157. Cruise control
  158. sound startering when i start the engine
  159. mounting front license
  160. Odd growling/whining when running
  161. P2422 EVAP CVS stuck closed
  162. electrics
  163. Help selecting a iPhone SE mount for use in 2013 Honda Fit LX
  164. Apple Maps voice navigation & 2013 Honda Fit: Lightning, USB, audio jack?
  165. Car stalls briefly in heavy rain
  166. honda fit 2007
  167. Lower exhaust note with clunk!
  168. Honda Fit Radio - No Sound
  169. Reviewing my 2008 Honda Fit (GD3) - VIDEO
  170. brake booster check valve location
  171. Misfire
  172. valve adjustment
  173. Is it safe to have the dash cam power cable near the side curtain airbag?
  174. intermittent AC issue
  175. 2015 Fit - rear hatch won't lock
  176. Mufflers for Honda Fit
  177. Buying original shocks for Honda Fit GD1 2002-08 model
  178. 2008 Fit, use non 151R batt?
  179. Battery Mystery
  180. Video summarizing my Honda Fit GD3 with modifications
  181. I think the Honda Fit I recently bought has serious structural issues
  182. Need advice please with engine noise !
  183. Buying a 2015 Honda Fit
  184. transmission and engine oils
  185. 2007 Honda Fit Multiplex Control Unit Replace
  186. manual transmission gearshift iffy
  187. 2008 Honda fit
  188. Clutch noise
  189. Timimg belt
  190. no ground to injector
  191. GK5 rear disc conversion
  192. check fuel cap kept coming on
  193. Honda Fit 2008 mirror and backing plate
  194. Replaced coils and plugs, CEL now flashing
  195. Seat belt replacement and airbag reset
  196. 2015 Honda Fit Front impact sensor
  197. Honda fit bumper replacement
  198. Knocking Noise in the Engine Bay
  199. Engine Knocking
  200. tailgate not opening after recall for door handle brackets fixed at dealership
  201. passenger side view mirror casing is loose.
  202. adding Cruise control
  203. Honda fit 2014
  204. Front tire alignment
  205. 2017 Honda Fit EX for Towing behind Motorhome
  206. Check Fuel Cap
  207. 2013 Sport - Power Steering Adjustment
  208. Honda Jazz instrument lights flashing and clicking noise!
  209. Battery needs charging: Remedial measures?
  210. My honda fit 09 radiator and condenser fans not working
  211. Multiple dash lights on
  212. varmint in my car
  213. Engine swap
  214. Battery Light On and Off- Bad ECU?
  215. TUTORIAL: Changing the ELD (with pics)
  216. Driver's side door lock "jams" and doesn't work properly
  217. Miss firing by honda fit aria 2004
  218. Three dummy lights on.
  219. Rebuilding B16A2
  220. sorry for the noob question
  221. Honda Fit 2008 - Side Mirror Issue
  222. honda fit
  223. Damaged rear axle
  224. Cigarette Lighter and Accessorty Outlet dead
  225. New fit owner /intake help
  226. 2004 Honda Jazz AC Issues **No Light**
  227. Size difference of L15 engine vs R18?
  228. Fir Misfires on start up
  229. Input shaft bearing going out
  230. Mounting Holster to Driver Side Floor
  231. 2007 fit under dash wiring
  232. Bent front end jacking improperly
  233. Honda fit 2016 lx-fans?!?
  234. AC compressor stays engaged, Low refrigerant
  235. Misfire Blues
  236. 2008 Honda Fit Sport Headlight/turn signal switch
  237. 2012 Honda Fit Sport - Replace TPMS Sensor
  238. 2012 Honda Fit - Replace 12v Fuse
  239. WordWorker
  240. Car Stereo Problem
  241. 3rd Gen (GK5), How-To: Fully disable traction and stability control (VSA/ESC)
  242. L15A1 mods
  243. Honda Fit AC panel help
  244. Alarm going off and doors auto lock issue
  245. I have a 07 fit that keeps blowing the IG fuel pump fuse
  246. LOL still think you need back pressure
  247. Questions about a 2010 Honda Fit Sport
  248. ignition
  249. 2007 fit, mode control knob not working
  250. RV-6 Performance Cat Pipe
