passenger side view mirror casing is loose.
Right side passenger electric side view mirror case housing around the the is loose. How do I tighten it. Not sure if one of the screws got loose or fell off.
Re: passenger side view mirror casing is loose.
"around the" ??? Door? Mirror?
I had to replace my passenger side view about 5 years ago. In my experience I replaced the whole, single unit and everything tightens from inside the door panel. I had to remove the pass door panel, take off a sheet of plastic (likely for dust?) and then access the mirror through some cutouts in the panel. Think it's all socket and maybe screwdriver, can't remember if you need a socket extension. Not terrible, but not fun. Hope this helps.
