Replacement Maser Cylinders for Honda Fit
I am looking for swapping out my current 2015 Fit EX MC with something larger. Any suggestions for a Honda or Acura compatible part?
Re: Replacement Maser Cylinders for Honda Fit
Not 100% sure but if it works similarly, it WOULD work... for example... i had a 91 CRX and the first brake upgrade i made was installing a 89 prelude MC and steel braided lines... and it made a WHOLE LOT of a difference.... again... it was my experience.... so theoretically it should work, since a larger piston is pushing.... I mean... why not try....
The only thing it would help is with larger calipers.
Well duh you can't compress any liquid no matter how much MORE force you try to apply. And all your "feeling evidence" is worthless.
"Larger piston in the MC should require more foot pressure for the same braking pressure."
A larger piston would require LESS foot pressure.
It's just not theoretical, I've changed to a larger diameter MC for a clutch in a manual swap and pedal effort was quite a bit higher.
You made me do math....
Civic MC is 13/16 with a surface area of .051 sq/in
MDX MC is 7/8 with a surface area of .060 sq/in
F = P * A, I picked 2000 PSI just as a reference number.
F of a Civic is 1030 lbs.
F of a MDX = 1200 lbs.
Assuming the rest of the system remains the same.
Keep in mind that the brake pedal and booster gives a bunch of leverage so, 100 lbs on the pedal might be 1000lbs on the MC.
Change the feel means nothing it's all supposition. No such thing as "pushback" in a hydraulic system. A larger master cylinder piston DECREASES the the force need because it is moving more fluid in the same time frame.
Change the feel means nothing it's all supposition. A larger master cylinder piston DECREASES the the force need because it is moving more fluid in the same time frame.
I guess we can agree that a larger piston moves move fluid for the same travel.. It's not timeframe but the travel of the piston that moves the fluid. So, for 1/4" of travel, the larger piston will move more fluid than the smaller.
That's a very Trumpian statement.... Despite the math you continue to claim something that isn't true.
What do you think it is that keeps the brake pedal off the floor when you press on it? The 100 lbs of pressure your foot is pushing on the brake pedal is being resisted by the pressure of the brake fluid. The harder you press, the more pressure you generate, the more the piston in the MC is pushing back on your foot.
For the same braking force, pedal pressure, line pressure, stopping power, however you want to define it.
Smaller master = longer softer pedal
Bigger master = shorter firmer pedal
MySelfAffliction
10
09-19-2004 08:10 PM
