2018 Honda Fit Tire Pressure Sensor issue
We have a 2018 Honda Fit that the Tire pressure sensor light came on the other day. Tires were checked and topped off (None of them were that low to begin with) as needed but the light never went off.
Does the spare tire have a sensor on it? Does the system need to be re-calibrated now that it was triggered?
Thanks in advance.
Thanks in advance.
Re: 2018 Honda Fit Tire Pressure Sensor issue
Every time you set your pressures or rotate the tires you need to recalibrate the system. It's also common when the weather turns cold to need to adjust pressures and calibrate. On your fit it's through the buttons on the right side of the steering wheel, watch the dash display. Go to vehicle settings - TPMS calibratate.
Barbie Pitts
Honda Civic (2016 - Current)
12
03-22-2023 04:40 AM
Grumpycloud
03-01-2014 07:36 AM
egyolk
12-12-2013 10:03 AM
EF_9
01-18-2008 07:19 PM
