Replaced coils and plugs, CEL now flashing
08 Honda fit. Purchased w/o records @ 106k, now 120K. Car started stumbling under load. Autozone pulled codes. P0301, P0302 and P0300. So, misfires on cylinders 1 & 2 and Random misfires. Decided to change all four coils and plugs. Used NGKIZFR6K13 plugs and Hitachi IGC0053. Plugs torqued to 16 ft/lb. Fired up after switch and ran like a top in the garage. An hour later I head out on an errand and within 150 yards CEL comes on and shortly thereafter it goes into flashing mode. Engine was still running perfectly smoothly.
I wont have access to a code reader until tomorrow but I cannot figure out what I might possibly have done incorrectly in such a simple task. I mean, I changed the timing belt and water pump in my 1990 Miata and that went fine. Any thoughts?
Re: Replaced coils and plugs, CEL now flashing
Try disconnecting your battery for a minute or so to clear the info in the ECU. Did you get fuel after, if so check your fuel cap is tight.
tpeter91
10-25-2010 06:33 PM
kaotikvizion
06-03-2008 11:19 PM
