Clutch noise
Clutch noise
Good Morning,
I drive a 2011 Honda Jazz 1.5 EX-S (Pre-facelift), the car has about 112500km on the clock at the moment.
Now these are my issues, there is a strange chirp noise if I put a little too much gas while releasing the clutch, doesn't happen all the time. After the vehicle has warmed up a bit, there is a squeak while releasing the clutch and while driving slow in low gears, but this squeak is not existent while in neutral. This noise is also heard if I lift the car and turn the front wheels while in gear, but not heard in neutral.
The next issue, but I am unsure whether it is related, is when I accelerate I hear what I would say is a metallic rattling, sounds like a loose bearing noise, but is most apparent if I am say, in the wrong gear trying to accelerate, or while cruising in a higher gear. (I have been informed my transmission mount is a "little soft", could this be the rattle?) and while slowing down with the clutch engaged with no gas.
If I rev the car in neutral or with the clutch disengaged, none of the above noises are apparent. There is however a slight moan at a certain rpm when the revs drop for I would say half a second - probably unrelated.
Any assistance would be greatly appreciated!
