manual transmission gearshift iffy
2012 Honda Fit Sport Manual. When shifting, can often feel two or three "detents" when going into the next gear. It doesn't feel smooth going from gear to gear. Also, sometimes the lever gets stuck in first gear for an instant before getting into 2nd. The timing of when I push the clutch in relation to moving the lever or revs doesn't seem to affect this.Is this most likely low mtf fluid, or is there another issue. I don't think it is the clutch.
Re: manual transmission gearshift iffy
Had the transmission fluid topped out. Gearshift lever still feels rough between shifts. Still don't think it's the clutch. What other things might cause this? Is there something out of alignment in the gearbox? Is this normal for a 2009-2013 Honda Fit 5-Speed?
prodjay10
Honda Civic (2001 - 2005)
08-13-2016 02:14 PM
acmoc
11
10-13-2012 08:27 AM
arielb1
12-12-2009 01:34 PM
pcorad
07-28-2008 05:42 PM
