PDA
View Full Version : Honda Fit
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13
  1. How-to: GK independent fog lamps
  2. Door lock problem
  3. 2015 Honda Fit - Panel warning indicator lights on
  4. JDM/EUDM GE6-8 cluster on USDM FIT HELP
  5. Please help me diagnose the problem
  6. From stop, R turn wheel hop
  7. kswap in az? 2010 honda fit
  8. End-user maintenance schedule documentation now obsolete?
  9. Shopping for Remote Starter
  10. 2010 Honda Fit base, no rear view mirror?
  11. Manual transmission help, hard to shift with engine on, clutch not disengaging fully?
  12. whos paying their car today.. THIS GUY
  13. 08 Honda Fit Hail Damage
  14. Disabling auto-A/C when directing air at windshield
  15. 2010 Honda fit idle issues
  16. Non-honda manual transmission fluid for Honda Fit 2007
  17. Headlights won't turn on
  18. GE8 Fit Headlight Disassembly
  19. 2015 Honda Fit Ex Idle Rev
  20. 3rd consumables (air filter, wiper blades
  21. Automatic shifter button
  22. Honda Jazz side mirror
  23. AC went up in smoke
  24. Finally installing seatbelts
  25. EGR valve and engine light
  26. Minimize risk of mold on AC condensor
  27. Noise in neutral with clutch released
  28. Opinions on chirping sound from '08 Fit
  29. HELP!!! 2005 Honda Fit
  30. New Honda Fit, looking for active forum
  31. Gen2 and Gen3 same front brake?
  32. E-Brake seems stuck...HELP!
  33. 2007 fit sport radio and dash turn off with AC on
  34. Amber rear turn signals on US 2015 Fit
  35. GE8 DIY Guildeline - Illuminated Auto Folding Side Mirror Switch
  36. Garmin GPS and FIT EX?
  37. Wow! Watch out for RODENTS!!
  38. Stutter/Shudder electrical problem?
  39. JDM Jazz Hood On USDM Fit?
  40. No A/C, serviced and new relays
  41. Reasonable to have tire place look at pull to left?
  42. Gurgling noise in the front?
  43. Where to get the accurate invoice price for fit? $16668 for 2015 fit, good or not?
  44. jazz 06 aux input problem
  45. 2007 Honda Fit/Jazz A/C Relay Location!?!
  46. Ge8 k swap?
  47. V6 Honda Fit Build
  48. tpms fuse 2009 Honda fit
  49. Deltacams
  50. Drivers' side view mirror - expanded view issue
  51. Tires for 17x7.5 wheels
  52. Permanent windshield fluid trickle above the driver
  53. Common Problems with Fit?
  54. Quote for 2015 Fit
  55. Air bag sensor not completely working
  56. 2015 Honda Fit GK5 at a local dealer with Momo wheels
  57. My daughter's drawing about Honda while waiting in service area
  58. Web Camshafts
  59. Magnaflow custom catback exhaust on my Honda Fit GD3
  60. KTuner ECU Reflash
  61. Rear spring question
  62. GD3 rear hatch shocks same as GE3?
  63. J'S RACING GK5 FIT3 SUS Circuit Converter (Cat Delete)
  64. GK fog lamp relay?
  65. 07 Fit - PCV Valve Location Help?
  66. Girls of the 2014 Bangkok Auto show
  67. While replacing battery, my wrench sparked between +/- posts. No power at all.
  68. Power door locks
  69. HELP!!!!!!!!!!!
  70. 2015 Fit Remote Start shutoff on door open
  71. Non Stop Tuning (NST) Custom Crank Pulley
  72. Honda Fit Airbag light wont turn off even while resetting it
  73. J'S RACING GK5 6MT hyper ECU - Reflash Dyno
  74. Coils for new fit!
  75. 15.264@90.80mph
  76. honda fit, cold feet
  77. Honda Fit 2008 168k miles Safe to buy or should i stay away
  78. 2015 CVT LX Weight Loss
  79. Stripping wiring harness - What are these things?
  80. fit oil change
  81. Myxal Reducing Diameter Exhaust
  82. Larger Throttle Body Modification - Maxbore
  83. 0-60mph in 7.42 seconds
  84. 15.813@87.18mph
  85. PRM Intake
  86. Accelerating CVT Faster
  87. Larger Maf Sensor Mofidication
  88. 2015 2" Flo Pro Max Muffler
  89. 2015 Throttle Body Coolant Bypass
  90. 2015 Myxal Intakes
  91. Fit 2008 Has Hiccups and Stalled at Red Light
  92. Power Choked? (have you seen this dyno result?)
  93. Brake Light Problem - 2008 Honda Fit 5-speed Sport
  94. Honda Fit/Jazz electrical problem ?
  95. Send air to windshield without A/C
  96. Removing carpet from trunk or how else to clean out laundry detergent?
  97. Anyone running slipstreams on fit here?
  98. ** Passenger HID not working after a few seconds?? **
  99. A friendly warning to Fit owners-------
  100. FIT Front Wheel Bearing, Loose but NO NOISE
  101. Adding 12 volt Outlets
  102. rod bolts for L15? what size
  103. '08 Left Front Stereo Channel Out - ideas?
  104. Honda City 2008 IAC problem
  105. What do you do when you sprain your ankle?
  106. 2013 honda fit
  107. Honda Fit door locks stuck
  108. 08 Fit with 120k KM
  109. Missing "skid" panel beneath engine compartment
  110. sold my hatch got a fit
  111. MES connector
  112. can u built a fiesta st fighter for $22K
  113. Is heater disabled when A/C is on?
  114. Hood Sctraches
  115. Flywheel/flexplate
  116. Help: Can't remove key without disconnecting battery and shifter stuck in park
  117. 2008 Fit Sport ABS light on
  118. Stereo complete! (Factory nav + sound processor)
  119. Hello from VA
  120. 2006 honda navi system (Fit)
  121. Wow!! Props to Accordguyintake on fitfreak.net!!
  122. Changing spark plugs & fuel filter
  123. Opened cargo cover perfectly positioned at face level
  124. Rim inspection before long trip?
  125. new 2013 fit sport question
  126. Odd request, need 09+ rear view measurements
  127. '09 Fit: Headlights always on?
  128. New battery for 2009 Jazz
  129. New Fit Owner - Extra Key?
  130. ek skunk2 on 2013 jazz?
  131. new shoes for the new year
  132. 2015 Honda Vezel
  133. Hearing/burning smell when turn up heater
  134. Honda specific fluids; check frequency for manual transmission fluid
  135. Transmission Fluid Change - Jazz manual g/b
  136. Surging at low RPM's 2007 MT Fit Sport
  137. 09 Fit P1172 & P2A00.
  138. 2007 Base Honda Fit: Intermittent grinding noise in right-front wheel
  139. 2011 Honda Fit - keyless entry locks but won't unlock
  140. honda jazz/fit 2005 p0638 & p0122
  141. Shudder at 115-135 km/h (72-84 mph)
  142. Civic vx wheels on a Honda Fit?
  143. H Fit Sport Rim theft
  144. Electrical Problems??
  145. Review- Visual Garage Shark Fin Antenna
  146. Expected life for 2007 Fit?
  147. Removing cover on back of tailgate
  148. 07 Fit Sport - Door locking issue
  149. Smart fuel injection and fuel inefficiency in flooring it?
  150. Use your Fit to cook Thanksgiving dinner
  151. About the USA second gen.
  152. Gurgling
  153. '07 base getting 25mpg? was in upper 30's, 173k miles
  154. 2013 Honda Fit horn replacement
  155. Honda City Type Z Outer CV Joints Problem
  156. 2012 Honda Fit Sport Manual electrical diagram
  157. Honda Fit 2013
  158. 1G Fit steering/trans/ignition lock reset
  159. Honda Fit / Jazz Hybrid engine tuning
  160. oem battery cost?
  161. 2007 Fit Code P2647 + Misfiring
  162. code po171
  163. Leaking oil from behind protection cover
  164. 2009 Honda Fit Sport OEM TPMS?
  165. Honda Fit 2011 Acceleration problem
  166. Debating on buying a used Fit when I sell my S2000. What should I look out for?
  167. 07 Fit SRS Computer
  168. Looking for engine bay dimensions
  169. Honda fit 08 Manuel
  170. Honda Fit B-Spec Racing Wins(Pirelli World Challenge) On NBC Sports Sat 7/20/13 4pm
  171. Recaros in a 09 fit. Few questions
  172. Windshield wipers going crazy?
  173. Shutting off when AC is on???
  174. 2014 Fit Brochure Scanned - Looks to be the final design to me.
  175. Fit dies at cold starts
  176. Diagnostic scanners
  177. 07 honda fit jdm cluster
  178. 2007 - 1st generation 1 Honda Fit / Jazz
  179. 2006 Jazz Hot Idle Problem
  180. TYpe R into FIt
  181. Tranmission's issue on GE8
  182. KONI looking for ‘09+ Fit near Cincinnati for strut/shock test fit. FREE PARTS
  183. Adding An Audible Indicator for Low Fuel in 08 Fit
  184. Just bought a Fit
  185. What oil to use in 2012 Fit
  186. where to buy tokico or kyb shocks/struts?
  187. where to buy cheap eibach pro kit online?
  188. Need Hond Fit to make exhaust systems
  189. 2002-2008 center arm rest. fits 2013?
  190. 2013 cargo cover
  191. Experiencing a power lag with my f20b
  192. 2011 front end on a 2012
  193. ooops. dropped pen into air conditioner slot
  194. Shock/spring replacement advice
  195. 2008 Fit rough low idle when cold
  196. Wheel and tire fitment
  197. chassis code
  198. 2009 Fit 15" Steel Wheel Offset and Hub Bore?
  199. Advice on buying a used Fit??
  200. FIT 2013 TPMS
  201. Honda Jazz 1.4 lx 2009 model
  202. Remote Frequency Honda Japanese Market Fit
  203. Honda Jazz
  204. You Call That a Bumper ?
  205. honda civic hatchback dx automatic 1.5L 1991
  206. how to open the traingle back cover (to open the side mirror)
  207. which one is the best?
  208. New Guy
  209. honda fit ev
  210. Tokico HTS Shocks
  211. how to unlock a honda fit door
  212. service manual issue?
  213. ECU Pin out data
  214. Acclerator / Gas Pedal
  215. Honda Logo Spark Plugs - Help Deciding...
  216. Tranny question
  217. How do I know if my 2011 honda fit has VSA?
  218. Jazz vs. Fit
  219. Performance Modifications for the Honda Fit/Jazz
  220. Help! Is 90000 miles too much for 07 Honda Fit?
  221. DTC Code P0847
  222. 2012 Fit Headlight & Fog Light Bulbs
  223. Good all season tires in the rain?
  224. DIY- Cargo Cover
  225. rain gutter roof rack attachment
  226. From Day 1 to 7/26/12
  227. Wrecked the Fit...guesses as to totaled/not?
  228. Tire fits
  229. intake flange
  230. Honda Logo 1.3 2000 - How to increase MPG?
  231. Clunk when downshifting
  232. Is my 2007 Fit Sport hydrolocked?
  233. Honda fit brake problem
  234. how do i reset the airbag light?? help please
  235. Dead 2009 Honda Fit auto
  236. 07 Fit 68K miles...problems
  237. Suspension question
  238. (ask) Honda Freed ?
  239. Looking to buy 07-08 Fit alloy wheels
  240. Looking at new 2012 Fit Sport (n00b questions)
  241. Comptech or HFP package???
  242. Dome light wiring question
  243. Quiet tires?
  244. Would like owner input on buying a new Fit
  245. Any OTHER cheap way to fix idle misfire??
  246. Honda Fit 2002 GD1 i-SDI 1.3L; Turbo kit
  247. Oil monitor, trustworthy?
  248. 2007 Honda Fit Sport Exhaust
  249. JDM 3rd brake lamp
  250. Please Help!! Pcm and Fuel Pump Problems 07 Fit
