2009 Fit stumbles and (apparently) misfires ... bad PCM?
Hi all!
A friend of ours has offered us the car (with a known issue that I can potentially fix) for a discounted price of $2,500, and I am pretty handy with a wrench and a scantool. He has loaned us the car for a couple of days so I can diagnose the problem and decide if I want to take it on. It's a 5-speed automatic base model with 180,000 miles.
Anyways, the main issue is that it intermittently stumbles, loses power and/or misfires, both when accelerating or while driving at speed. According to our friend this has been a minor issue and he has only noticed a slight 'hiccup' from the engine once in a while.
The CEL was off when I got into the car to drive it to work today, and while en route there were a few distinct cases where it sputtered or hesitated. But overall, it was a smooth drive.
On the way home it was much worse. It totally lost power coming off a red light and went into limp mode. The CEL came on and started flashing. Even with the pedal to the floor it didn't want to accelerate and it was difficult to get above 15-20 mph.
I pulled off the road and turned the engine off and on again; the CEL stayed on (solid, no longer flashing) but it was out of limp mode. I was able to maintain regular speeds the rest of the way back with a few sputters; more or less it was safely driveable.
I pulled the codes immediately after pulling in the driveway; here's what I got:
P0304 - Cylinder 4 Misfire
P2610 - M/PCM Internal Engine Off Timer Performance/Malfunction
Based on Google's interpretation of P2610, my immediate assumption is to ignore the misfire (coils/plugs) and go straight to the "replace PCM" option. What do you think? I'd need to check the exact part number but it looks like used PCMs for this model go for around $100 on ebay.
As for the rest ... our friend told us that the car probably needs a strut (sounds/feels like the front driver's side) but that's not a big deal for me; a strut tower assembly is ~$100 and I can probably knock it out in an hour or two. The body and interior are in good condition and everything is factory. Tires are basically new. I would get a stack of maintenance history with the car and it's been fairly well maintained.
So... am I on the right track, or is it likely there's a hidden (bigger) problem lurking here? Also, if I were able to replace the PCM (cheaply) and it solved the main problem, are there any hidden gotchas like needing to reprogram VINs, keys, or get new keys made?
Would you give this car a shot?
Thanks for reading this far!
Re: 2009 Fit stumbles and (apparently) misfires ... bad PCM?
Two things to check first they are common problems in Fit with high mileage and cause the symptoms you describe.
First valve clearance adjustment.
second plugs and or sparking units.
For the strut problem first check the space between the strut retaining top and the body. They are known to have increased clearance with higher mileage that causers knocking sound. If it is excessive buy a new retainer and remove the rubber lip and super glue it to the bottom of the old retainer and re-install.
Mutogia
Honda Fit
05-09-2018 11:48 PM
Schnitzer
05-11-2014 05:15 AM
Prof007
12
01-11-2009 05:04 PM
