2013 Fit - Hard to stop
Hello,
I can't seem to find a similar problem. 2013 Fit. I've had the mechanic look at it and they can't find the problem. The car will stop, but I have to push a little hard on the brakes - not stand on them, but push harder than I should have to. It's been like this for about a month - hasn't gotten worse. I checked the booster by pumping the brakes when the car was off then holding the the pedal and turning the car on - the brakes went down. The fluid is full, the brake pads and rotors are about a year old. This started about 2 weeks after the valves were adjusted. Doesn't make any noise. Doesn't seem to get better or worse, although, I notice it a little more in the morning when I first drive it. I think that's just because there isn't a gradual breaking, the pedal goes down to a point where it's hard then I need to push harder to stop. Any ideas? Thank you!
