exhaust temp
Old May 23, 2007 | 10:22 AM
redsolturbo's Avatar
Default exhaust temp
yoink, im just playing around with an idea, but genrally what heat ranges to exhausts run up to heat wise? i know a manifold gets baking hot, just more curious about the cat back area?
cheers
Old May 25, 2007 | 07:53 PM
codenamezero's Avatar
u wanna try aluminum catback? hehe...
did some number look up before, for NA, right out of the engine is about 800-1000, and FI is about 1200-1400. And i was told that the temperature "quickly" fall off... i would "assume" after cat would still be about 600ish just to be safe...
i don't have any infrared temperature reader, i was going to aim that at the cat to have a better guesstimate.
if you have a infrared scanner, try it out.
Old May 28, 2007 | 04:44 PM
Sims's Avatar
Default Re: (codenamezero)
Stainless headers/exhaust will give you readings around half of what you mentioned with a temp gun.
Old May 28, 2007 | 04:50 PM
m R g S r's Avatar
Default Re: exhaust temp (redsolturbo)
wtf is yoink?
Old May 28, 2007 | 05:41 PM
NJIN BUILDR's Avatar
Default Re: exhaust temp (m R g S r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">wtf is yoink?</TD></TR></TABLE>
Uk brother.
Old Jun 8, 2007 | 06:29 AM
Default Re: exhaust temp (NJIN BUILDR)
no, actully i was looking at plastic :lol: (seriously) the stuff they make riot sheilds is ment to be good for a constant 600 deg celcius. just thinking how easy it would be to make a batch as opposed to having to weld a load of pipe together :lol:
crazy *** idea that went out of the window when i sobered up :lol:
cheers
Old Jun 8, 2007 | 07:54 AM
Andy R's Avatar
No expert, but I would think that the problem with polymers is that the chemicals/gases found in the exhaust stream can break down the bonds without using expensive resin's. I'd stick with metals. If you design it right, there shouldn't be much welding (unless your rolling your own tubing )
tgreene2098
Jul 20, 2007 08:22 PM
invisible
11
May 15, 2007 03:47 PM
Azn Kenny
Nov 13, 2005 02:09 PM
matttegra
Sep 16, 2003 04:53 PM
jas_honda_uk
Mar 13, 2002 10:30 AM
