synchrowave or dynasty
Old May 12, 2007 | 06:36 PM
vtecspeed1320's Avatar
Shooting Star
Default synchrowave or dynasty
Im trying to figure out which one of the 2 to go with. Price is no concern, anyone with experiance in both would be great. It will be used for small automotive fabricating, i.e. manifolds, down pipes, etc etc. What are some of the more noticable differences, not the size etc. Anyone with the real world experiance in both welders would be greatly appreciated. thanks everyone.
Old May 12, 2007 | 07:28 PM
atutt's Avatar
if it's gonna be used for "small automotive fabricating", then don't spend the extra money on the Dyanasty... Unless space is of a major concern... Plus the Syncro has a higher amperage range...
The Dynasty has more and nicer features but would seem useless to you unless you do A LOT of aluminium...
I'd jsut go with the Syncro, it seems like it would be better suited for your needs?
Old May 12, 2007 | 07:32 PM
dfoxengr's Avatar
Default Re: (atutt)
i have a sync 200, and we have a dyn 200 at our lab at school i use some, most f the time i use a sync 250 there.
the setings are actually quite similar between the two. only differences i really see are the size, lol, and with aluminum the inverter technology is great. it uses a larger frequency range for aluminum welding so is more adjustable there.
but itd only be worth it to you if you really were going to do tons of alum. welding.
good luck
Old May 12, 2007 | 08:23 PM
dave@passenger's Avatar
Default Re: synchrowave or dynasty (vtecspeed1320)
If cost is no object get the dynasty, way better for aluminum, very small and light, uses far less power. I've had both, I prefer dynasty.
Old May 12, 2007 | 08:41 PM
Shooting Star
the only aluminum id be welding would be IC and IC piping.
I was planning on getting the sync then someone also planted the dynasty seed...i dont think i need it but i thought i would check out what some people have to say about the 2.
Old May 13, 2007 | 05:17 AM
dfoxengr's Avatar
Default Re: (vtecspeed1320)
right, if money isnt a problem then theres no reason not to get the dyn.
but if youd rather spend the extra 1000 on tanks, hemet, all cup sizes and gas lenses and their cups, and a better torch, then you might think aboout that.
Old May 13, 2007 | 06:09 AM
Shooting Star
yeah thats another thing that was weighing on me, i could buy a ton of extras for the sync and still have less money in it then the dyn. I weld at work so helmet is no biggy. And since the place I work has about 150 miller welders...I get a discount on alot of the products, except s.s. filler rods...that ***** expensive as fawk.
Old May 13, 2007 | 01:56 PM
essex's Avatar
Well if money is no problem go see a dynasty in person compared to a sync then think about being able to take that dynasty anywhere pretty much as it can be used on multiple power outlets. It's very versatile. You don't even need to wire up a dedicated circuit for it ,just run it off a dryer plug even and it will do anything you want. Run it off a regular household 15a plug and you can pretty much do all sorts of steel work.
Thats if money is no problem though.....don't forget to look into the thrmal arc.
Old May 13, 2007 | 02:02 PM
Bailhatch's Avatar
Default Re: (essex)
I use a Dynasty 300 and it's defiantly does stand out for it's great AC welding but it's also ~8k retail, plus cooler, cart etc... if money's no object, do it
Old May 13, 2007 | 06:48 PM
Shooting Star
my garage is already wired for a 3 phase power source...i dont need a dynasty 300, thats way more machine then i would ever use.
Old May 13, 2007 | 07:11 PM
TIGboy's Avatar
dynasty 200dx
Old May 13, 2007 | 07:16 PM
bigTom's Avatar
Default Re: (TIGboy)
I have a dynasty 300dx and absolutely love it. I'v used the synchro 200 before as well. For steel they are pretty much the same IMO but for aluminum the dynasty has way more features being that it uses inverter technology. Is it worth the price tag? I believe so. My welding has significantly improved since I aquired it. Once setup correctly welding aluminum for even a beginner is a breeze.
Old May 14, 2007 | 03:01 AM
Bailhatch's Avatar
Default Re: (bigTom)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigTom &raquo;</TD></TR><TR><TD CLASS="quote">Iwelding has significantly improved since I aquired it. Once setup correctly welding aluminum for even a beginner is a breeze. </TD></TR></TABLE>
Ya, i cant weld for **** so this machine makes it look like I can
Old May 14, 2007 | 03:15 PM
k24em2's Avatar
Default Re: (Bailhatch)
Dynasty if you have the money.
Old May 14, 2007 | 06:35 PM
Shooting Star
hmmmmmmmmmm....cool ill check them out more.
Old May 14, 2007 | 06:44 PM
CRMB's Avatar
OG Fabricator
The difference between the cost of the syncrowave and dynasty slims when you consider the difference in the power bills between the two.
Old May 14, 2007 | 06:45 PM
Race Egr's Avatar
Its like saying big and bulky vs small and adjustable, Dynasty all the way
Old May 14, 2007 | 07:29 PM
abnaasefmb's Avatar
Default Re: (dr.NAPIER)
sorry to piggyback, but is this a good deal and what hidden cost will there be, besides wiring, gas and expendables. thank you.
http://cgi.ebay.com/MILLER-SYN...wItem
Old May 14, 2007 | 07:40 PM
dfoxengr's Avatar
Default Re: (abnaasefmb)
only problem with ebay dealers is if theres a warranty problem, they wont help you, you have to goto a local miller authorized repair shop, which most welding shops are.
Modified by dfoxengr at 10:39 AM 6/17/2008
Old May 14, 2007 | 07:44 PM
abnaasefmb's Avatar
Default Re: (dfoxengr)
hum, i really don't mind the extra 120, more worried about hidden costs. thanks.
Old May 14, 2007 | 07:52 PM
dfoxengr's Avatar
ok waste it then. not my money.
no hidden costs.
Old May 14, 2007 | 07:56 PM
abnaasefmb's Avatar
Yeah I know a penny saved is a penny earned, do you have any info on where to find one for that price? thanks
Old May 18, 2007 | 06:01 PM
locash's Avatar
I'll add my 2 cents..
in July 2004, I bought a new Dynasty 200dx with the intention of learning how to tig. Unfortunately, life got in the way, and I never used it until 2 days ago. The HF start does not work at all. I think the unit *might* still be under warranty, but this is still rediculous.
Ah well, so much for learning how to tig, I dropped it off at a Miller service center, we'll see if I have to pay anything, and how long I have to wait.
Old May 18, 2007 | 07:28 PM
essex's Avatar
Default Re: synchrowave or dynasty (locash)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by locash &raquo;</TD></TR><TR><TD CLASS="quote">I'll add my 2 cents..
Ah well, so much for learning how to tig, I dropped it off at a Miller service center, we'll see if I have to pay anything, and how long I have to wait. </TD></TR></TABLE>
Wow are you serious please post up because if my hf goes I wana know how much...I'm out of the warrenty, sorry to hear that
Old May 18, 2007 | 07:36 PM
Race Egr's Avatar
Ive seen a few people on the miller board have the same problem with there's. Im sure miller will take care of it for you. Id go ask around over there though
