Need tips on this.
Old May 11, 2007 | 01:14 PM
GeeGee's Avatar
Default Need tips on this.
I was wondering if there was a certain technique to help you rotate your torch to keep the same angle with a pipe. I can lay a decent beads but they're are short since I can't seem to rotate my torch as I go, I concentrate too much on keeping the hand steady and the bead consistent.
Old May 11, 2007 | 01:16 PM
atutt's Avatar
There a turn table gizmo that is made for welding consistantly around pipe/tube... they're expensive though
Old May 11, 2007 | 01:21 PM
GeeGee's Avatar
Default Re: (atutt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by atutt &raquo;</TD></TR><TR><TD CLASS="quote">There a turn table gizmo that is made for welding consistantly around pipe/tube... they're expensive though</TD></TR></TABLE>
I'm sure if it was one long piece of pipe I can come up with a jig in no time, but Im talking about bends/manifolds.
Old May 11, 2007 | 01:38 PM
GTiR NX's Avatar
Default Re: (GeeGee)
tack a scrap on the back side of the fitting so that it will spin. You can make a cheep one out of an old sewing machine and an old lathe chuck. or better yet just use a chuck and a friend to spin it.
Old May 11, 2007 | 02:27 PM
dfoxengr's Avatar
practice is all that can help you.
also use sme blocks under your hand to rest on.
Old May 11, 2007 | 03:58 PM
ManBearPig4silly's Avatar
It really just comes with practice. You can learn to skid or walk your cup as well. That actually makes it pretty easy.
Old May 11, 2007 | 06:35 PM
rob...'s Avatar
Default Re: Need tips on this. (GeeGee)
im guessing that your welding a groove weld on the 2 peices of pipe, if so here is my technique-
try holding the collet body and the handle at the same time,some times i use my pinky to help follow the contour. and welding towards you seems to help also. i.e. place the seam perpendicular to your body and hold the welding rod over your shoulder and dip in your puddle fron the front. i mainly weld pipe all day, and this seems to be the most comfortable postion to me.
E-Rok
Welding / Fabrication
15
Mar 1, 2009 08:54 AM
LukieLuc
Dec 3, 2007 07:22 AM
GForceInteg
Mar 30, 2005 02:01 PM
Kwuaymaikrup
Feb 16, 2005 02:46 PM
Sport_Injected
Oct 30, 2004 04:34 AM
