help on welding runners
Old May 18, 2007 | 04:14 AM
crxsir23's Avatar
Default help on welding runners
i have a question ween you guy's are wilding your runners ween they are so close their touching or for that matter at all do you guys make a jig to hold them in place so they cant warp because i never see any tack welds on them or is it one of thous thing that if your really good no if not yes
Old May 18, 2007 | 06:11 PM
RC000E's Avatar
Default Re: help on welding runners (crxsir23)
Best deal I have come onto here is from Weirtech on here. I have tried it and it is certainly the best way.
Leave your manifold in the jig you made it in....that is whatever locates the collector in relation to the head flange (if you don't have this already then you have more issues to deal with than just this warpage). Once the mani is tacked in 4 to 6 points at every joint, remove two runners so you can access whatever two you leave in place.
Weld the runners that are still attached to the headflange and collector entirely, except don't weld them to the head flange or the collector. Once your done, reattach the unwelded runners then remove the finished runners after they are entirely cool. Weld these runners entirely, then when done, reattach the runners finished prior and finish weld them to the collector and headflange....done....and everything still fits perfectly
Old May 18, 2007 | 09:30 PM
crxsir23's Avatar
Default Re: help on welding runners (RC000E)
cool thanks alot
Old May 19, 2007 | 03:38 PM
m R g S r's Avatar
Try studying English a bit also
Old May 19, 2007 | 05:08 PM
crxsir23's Avatar
Default Re: help on welding runners (m R g S r)
tank fur pont out not no des
Hatch99
Welding / Fabrication
Jan 25, 2013 10:22 AM
hoochhenry
Dec 5, 2011 07:15 PM
92cxturbo
Apr 18, 2011 07:03 AM
AWOC
15
Oct 13, 2010 05:23 AM
jjspec
38
Dec 29, 2009 04:42 PM
