Skunk 2 cams on b18c4
Old Oct 18, 2020 | 03:17 AM
mjbjck's Avatar
Default Skunk 2 cams on b18c4
Hi all, just looking for a bit of advice.
I have stage 2 cams installed now with springs and retainers. The compression on a B18c is quite low for NA to gain power with cams I believe. What high compression pistons would I need to suit the stage 2 cams which would be safe for clearance?
Old Oct 18, 2020 | 10:25 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Skunk 2 cams on b18c4
Pro or Tuner ?
Old Oct 19, 2020 | 01:59 AM
mjbjck's Avatar
Originally Posted by JRCivic1
Pro or Tuner ?
tuner
Old Oct 19, 2020 | 09:15 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Skunk2 Tuner 2's will work very well with a stock GSR short block.
Old Oct 20, 2020 | 02:22 AM
mjbjck's Avatar
the pistons I’m looking at are 12.1 domed. Just worried about clearance with stage 2 cams.
Old Oct 20, 2020 | 07:23 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Originally Posted by mjbjck
the pistons I’m looking at are 2.1 domed. Just worried about clearance with stage 2 cams.
If you have a stock surfaced head and a standard thickness head gasket, you will be just fine unless you introduce a ton of cam overlap.
