2003 Pilot AC Compressor Clutch help
The bearing under that pulley is junk. You might get lucky and not have damage to the snout of the compressor and can just replace the bearing. Otherwise it is a whole new compressor.
Eventually that pulley is going to do something stupid and cause the accessory belt to come off potentially causing damage to other accessories on the belt. But probably the biggest issue is when it comes off you will no longer have power steering assist.
Fire is also a real concern. No bearing means metal on metal and a lot of heat build up.
A bypass pulley might be a good option for you. Cheaper than the bearing on the compressor.
Something like this.
https://www.rockauto.com/en/moreinfo.php?pk=12284861
All you need is a new bearing or clutch pulley which you can get from a clutch set. You can get these dirt cheap off ebay. Just make sure the clutch air gap is within spec by using the right amount of shims which should come in the kit.. You will just need a 3 arm puller to get the old clutch pulley off after zipping off that bolt on the end. Nothing internally should be bad unless you keep running it and seizes.
dgdarien
Jul 2, 2021 01:05 PM
jermo
Acura TSX
Oct 12, 2017 10:23 AM
