Anybody swapped a crankshaft from a different engine?
Old Jan 8, 2021 | 12:10 PM
91integraLSVTEC's Avatar
Default Anybody swapped a crankshaft from a different engine?
sup yall got a b18 css block without a crankshaft and main caps. i have a junk b18 block but the crankshaft and main caps is still good according to the bearings. can i swap over the crankshaft and maincaps from the junk b18 onto the css b18 block without any machining?
Old Jan 8, 2021 | 06:02 PM
Ryanthegreat1's Avatar
Default Re: Anybody swapped a crankshaft from a different engine?
A little research would answer your question more completely but the short answer is no.
Old Jan 8, 2021 | 09:09 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Without any machine work... the LONG answer is NO too.
Old Jan 9, 2021 | 09:41 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
And the yes answer is, WITH machining you can get the crank and caps sorted in the new block. Might require over sized bearings once they are done.
Old Jan 11, 2021 | 11:30 AM
DaX's Avatar
DaX
Loved
Community Favorite
Can you do it without machining? Sure. Best case scenario is you get lucky and it all works. Second-best case scenario is that when you torque down the mains it's so bad you can't even turn the crank over so you stop there and take it to a machine shop, and you're probably out the cost of a set of bearings. Worst case scenario is you torque the mains down and you can still turn it some, then you finish assembling it and spin a bearing right off the bat and ruin the crank and block.
So...should you do it without machining? No way! The proper way to do this would be to have the mismatched block and main caps line bored and honed, then inspected for ID. Have the crank polished and inspected for main journal OD. Then, knowing these two dimensions, you can calculate bearing size based on your desired bearing clearance. Do it the right way and succeed.
Old Jan 11, 2021 | 03:47 PM
But that is the expensive way. /s
Jamison
Jul 15, 2011 11:20 AM
Icon_Ed6
11
Jul 10, 2011 05:05 AM
B18C_EJ8
Sep 14, 2007 08:15 AM
x91crxsix
Jul 21, 2006 08:59 AM
7rrivera7
Jun 23, 2006 12:14 PM
