head bolt check
Old Nov 15, 2023 | 05:37 AM
clickbang's Avatar
Default head bolt check
have the head off my jazz fit 2003.
just wondering if i should replace them,or is there a length check for stretch,to reuse them
Old Nov 15, 2023 | 08:16 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: head bolt check
What does your factory service manual say about this ?
Old Nov 20, 2023 | 05:38 AM
hondamark35's Avatar
Originally Posted by Mondysh
When it comes to head bolts, the general recommendation is to replace them whenever the head is removed. Head bolts are often designed as torque-to-yield (TTY) bolts, which means they are designed to stretch a certain amount when torqued to specification. This stretching provides the necessary clamping force to ensure a proper seal between the cylinder head and the engine block.
TTY head bolts are uncommon on Hondas. Inspection for damage to the threads or "necking" of the shank from being over-tightened is recommended as is a thorough cleaning before reuse. Otherwise they can be reused more than the number of times one could be bothered to rebuild an engine.
to be pedantic... when used for a clamped joint, all bolts stretch and achieve necessary force when installed to spec.
The "selling point" of TTY bolts is the reduction of variables that may cause out of spec clamp loads like friction of threads, presence of lubrication, bad tool calibration, ect.
OP: I'm with JRCivic1, check the factory service manual. It will mention in the notes that a head bolt(s) require replacement if that's the case. Also a torque spec followed by "...rotate another 180°." is another sign original bolts should not be reused.
ablorxk
Dec 12, 2007 03:37 AM
Beau Gotti
Sep 10, 2006 12:25 PM
ltho1998
Aug 16, 2003 06:59 PM
accordfreak
Apr 22, 2003 01:37 PM
rpm9100
Feb 3, 2003 11:17 PM
