Frustrations with Tapered ring compressor.
Old Jan 1, 2022 | 12:23 PM
Spaceturtle917's Avatar
Default Frustrations with Tapered ring compressor.
I thought these things were supposed to be a breeze. But the piston will not go in, even with some gental taps. It stops right at the first oil ring.
D16Z6 75.5mm overbore. Vitara pistons, 0.0035 p2w.
The piston slides right through the ring compressor without issue if it's off the block.
Old Jan 1, 2022 | 02:26 PM
Ryanthegreat1's Avatar
Default Re: Frustrations with Tapered ring compressor.
Continuous downward pressure on the piston while doing a swirl motion with the ring compressor. This will walk the rings into the bore.
Not a twisting but a swirling.
Old Jan 1, 2022 | 02:36 PM
I think I found my issue. My machinest put no chamfer on the block.
Old Jan 2, 2022 | 06:51 AM
Shouldn't need a chamfer with a tapered ring compressor as you have. A bit of finesse with the tool you have will get it to go.
Make sure your rings gaps are correct.
Freemananana
Engine Machining & Assembly
26
Oct 15, 2015 09:13 AM
dem0nk1d
Nov 12, 2012 12:43 PM
8VEYBEYB
18
Jul 20, 2009 07:44 AM
aznboi_2
Apr 26, 2009 09:36 PM
ysrhatch
Aug 30, 2001 09:37 PM
