Checking main caps befor aligne hone
Old Sep 16, 2020 | 01:29 PM
purposebuilt's Avatar
Default Checking main caps befor aligne hone
hi . I got a block from a friends but he wasent sure if they where the matching main caps. So i was woundering if theres a way to check the main journals to see if it needs aligne honed.
Old Sep 16, 2020 | 08:08 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: Checking main caps befor aligne hone
You would need the proper looooong handle bore gauge and measure the bores in 2-3 spots all the way through the girdle and then measure your crank and see if the number stamps match up to your measurements and honda bearings. That's usually a good sign if it all ends up right. I'm not sure if the mains are perfectly round so I can't say finding a slight out of round is an indicator or not.
I also don't remember if the girdle has the same sort of split number stamp like the rods do. You can sometimes tell when rod caps get mixed as the #2 or #3 etc doesn't line up over the split between the rod and cap.
Old Sep 23, 2020 | 09:36 AM
MotorMouth93's Avatar
10 Year Member
If there's any doubt at all, have it line honed. It's cheap compared to an engine build and a good idea on old engines in general.
purposebuilt
Sep 14, 2020 02:22 PM
toxictom
Engine Machining & Assembly
Jun 24, 2017 10:28 PM
pettyboy69
Apr 18, 2013 06:09 AM
b00stedOne
Jun 29, 2010 12:59 PM
metal-x
Oct 3, 2002 12:19 PM
