'96 Accord Rocker Assembly problem
Old Aug 1, 2020 | 04:26 PM
Anon_Accord2346's Avatar
Default '96 Accord Rocker Assembly problem
I own a 1996 Accord and I was replacing the spark plug tube seals and I flipped the rocker assembly upside down without the bolts in it (big mistake). My friend and I tried to put it back together and we couldnt get it to set in right. He was bent on tightening it down and it would pull it in to place, which he tried and it didnt work so I convinced him to give up. Well after reading through this and other forums Ive figured out that we messed up. How caj I re-compress the rocker assembly? I already have to go the the junkyard to get a bolt that came out stripped (not our fault). Should I just get another assembly or try to fix mine? Please help me as this is our space car when our others break down and we really need it going again!
Old Aug 1, 2020 | 06:54 PM
Default 1996 Accord Rocker Assembly wont go back in
I own a 1996 Accord and I was replacing the spark plug tube seals and I flipped the rocker assembly upside down without the bolts in it (big mistake). My friend and I tried to put it back together and we couldnt get it to set in right. He was bent on tightening it down and it would pull it in to place, which he tried and it didnt work so I convinced him to give up. Well after reading through this and other forums Ive figured out that we messed up. How can I re-compress the rocker assembly? I already have to go the the junkyard to get a bolt that came out stripped (not our fault). Should I just get another assembly or try to fix mine? Please help me as this is our space car when our others break down and we really need it going again!
civicrtype
Sep 2, 2011 03:43 AM
69GTOby
Nov 6, 2009 06:28 PM
xlogit3k
Apr 26, 2008 11:43 AM
Findingo
Aug 29, 2005 06:53 PM
