B18c1 block. B18b1 crank
Old Dec 18, 2022 | 07:27 PM
Dread187's Avatar
Default B18c1 block. B18b1 crank
Stroker b18c1 block, I spun a bearing(s) . Gsr crank possibly salvageable. I have my ls complete long bock. I want to use the LS crank in the Gsr block, aka Stroker. 81.5 mm wiesco piston 11:1 compression. Forged Ls rods, ACL .001 bearings . Gsr oem oil pump and timing belt and water pump. Skunk2 lma head is fresh from the machine shop. Hondata 300 . Aem fuel pump, 750 cc rc injectors . Any thing I may need or any help I would appreciate it.
Old Dec 18, 2022 | 08:22 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: B18c1 block. B18b1 crank
Pay attention to the crank counter weights making contact with the oil piston spray jet nozzles... you may have to bend them slightly for proper clearance or plug them off if the interference is too bad. This is a common engine build combination.
Old Jul 22, 2023 | 07:02 PM
K20.ek's Avatar
Correct. My ls crank hit the oil squirter bolt so I had to plug them with Eagle oil squirter plugs.
Old Jul 31, 2023 | 02:40 AM
blackeg's Avatar
I have been using this combo for a solid 10 years now. As mentioned, plug the oil squirters. Main bearings are the same, you need to use ls rods and ls rod bearings.
poweredbyb16
Sep 17, 2008 04:07 AM
crawlin
Oct 30, 2007 09:39 AM
TegRaceR98
Nov 23, 2004 10:02 PM
PhantomRacerGSR
Mar 16, 2003 04:49 AM
