Transmission & Drivetrain Gearboxes, Differentials, Clutches
Problem with 5-speed Back-up light switch
Old Nov 19, 2009 | 05:07 PM
iCollectStraws's Avatar
Default Problem with 5-speed Back-up light switch
I just noticed today that my reverse lights turn on and off at times while driving. I thought the switch was faulty at first but then I pulled it out of the transmission and left the electrical connector plugged-in still and the lights no longer came on. If the switch was faulty wouldn't the lights still flash on/off regardless of if the switch is in the tranny or not? If I pull it out and manually push the "button" on it the lights act perfectly normal. Also, I was looking for a replacement, is there supposed to be a washer on it and could a missing washer cause it to hit the fork shaft making it active before it's even in reverse? I noticed mine doesn't but on Hondapartsnow.com it shows a washer.
Old Nov 29, 2009 | 10:09 PM
Linked's Avatar
Default Re: Problem with 5-speed Back-up light switch
there should be a washer on it
Old Nov 30, 2009 | 10:00 AM
Honda Bull's Avatar
Get a washer and make sure it's tight. Then see where you stand.
JDMJUNKIEMONKIE
Oct 25, 2009 02:17 AM
ttk3
Lighting
Jan 14, 2008 04:34 AM
jArceo
Feb 14, 2006 11:25 AM
Ham'ed Hatch
Audio / Security / Video
Jan 7, 2003 11:14 PM
