Transmission & Drivetrain Gearboxes, Differentials, Clutches
D16 Diff bearing Ques
Old Dec 13, 2009 | 10:30 AM
1991civicsi's Avatar
Default D16 Diff bearing Ques
I am trying to install new differential bearings on my Mfactory LSD which will be installed in a cable D16 Si trans (PL3 3000)
I received my bearings from Majestic Honda and they are obviously for the 35mm case.
I ordered diff bearings for my 1991 Civic Si.
Part # 6207
91005 PL0 008
So, upon research I see that two part numbers are given for the 40mm case.
I searched for a 1989 CRX Si and 1989 Civic Si
Part # 6208
91005 PL3 B04
1994 Civic EX
Part # 6208C
91005 PS1 003
Which ones should I order for the Mfactory LSD inside the 40mm case? The 1608 or 1608C?
**BTW since the 35mm bearings are special order, they cannot be returned. If anyone has a need for them LMK. **
Old Dec 13, 2009 | 02:01 PM
Aquafina's Avatar
Default Re: D16 Diff bearing Ques
I've got MFactory 40mm diff bearings in stock. Give me a call if you need them.
If you are dead set on OEM (no reason to over the MFactory bearings though) order them for a 95 Civic EX.
Old Dec 13, 2009 | 03:28 PM
Thanks for your help. I really appreciate it.
Old Dec 13, 2009 | 04:15 PM
Mista Bone's Avatar
D Tranny Guru
Did you order axle seals as well?????
Might wanna check the number on the drivers side, Honda also has that messed up listing a wagon axle seal instead.
Generally when I order all bearings and seals, I stay within 92-95 era due to correct part numbers.
Old Dec 13, 2009 | 05:49 PM
Hmmm, Ill check. Thanks for the heads up.
cougar289
Jul 28, 2009 06:16 PM
speeddave
Apr 29, 2009 11:35 PM
jwyndsdime
May 8, 2007 07:15 AM
fullracegsr
Feb 12, 2006 07:44 PM
