Transmission & Drivetrain Gearboxes, Differentials, Clutches
inputshaft movement.
Old Dec 2, 2009 | 07:08 PM
projectTeG's Avatar
Default inputshaft movement.
ok, looking at a tranny to rebuild and i found one, but the inputshaft moves up and down when you wobble it, i know its needs the isb, but im sure movement like that is not to good for the rest of the tranny. is it worth getting?
Old Dec 3, 2009 | 01:03 AM
Aquafina's Avatar
Default Re: inputshaft movement.
Likely not. That much movement means one of the mainshaft bearings exploded.
Old Dec 3, 2009 | 03:23 AM
projectTeG's Avatar
well, let me not exagerate, it wobbles it has play in it.
Old Dec 3, 2009 | 04:29 AM
Aquafina's Avatar
If the ISB had exploded, then the clutch housing likely needs to be replaced.
Old Dec 3, 2009 | 06:39 AM
Honda Bull's Avatar
If you pick it up, make sure you get it pretty cheap so that in case you have to possibly replace more than you think right now, so it won't be a complete waste.
Old Dec 3, 2009 | 07:01 PM
projectTeG's Avatar
where are the detents on this style trans? i have the helms for the 90-93 teg, but it only shows the break down for the 92-93 big spline case.
Old Dec 4, 2009 | 04:16 PM
projectTeG's Avatar
the isb was the only thing trashed. what do yal think about the guts? i have no clue what im looking at. i see the syncros and they are pointy like the helms says.
this is the only gear im worried about
Old Dec 4, 2009 | 04:24 PM
projectTeG's Avatar
also i marred up the housing where the isb goes when i removed it. i was thinking about using my y1's clutch case was just swapping the guts. or could i use the j1's case?
Old Dec 4, 2009 | 04:25 PM
Aquafina's Avatar
Dog teeth on two of the gears look worn. 1/2 hub is scratched up, slider is probably worn, 1st gear is damaged. If that trans came to me, I would recommend replacing the above items.
Old Dec 4, 2009 | 04:51 PM
projectTeG's Avatar
k, sorry for the newb questions, how can you tell the hub is scratched, the first is worn, and the dog teeth are worn? again im sorry for the newbness
Old Dec 4, 2009 | 07:29 PM
Aquafina's Avatar
Looked at your pics.
Old Dec 4, 2009 | 08:13 PM
projectTeG's Avatar
is it the dogteeth on first or is it the gear itself? im just trying to learn what to look at now for future reference
Old Dec 4, 2009 | 11:10 PM
Aquafina's Avatar
Gear itself.
Old Dec 5, 2009 | 04:18 AM
projectTeG's Avatar
oh ok, im going to go look at it and see if i can see it. today im yanking out my y1 and opening it up and seeing whats going on on the inside. i appreciate yals input and help, honda-tech at its roots!
Old Dec 5, 2009 | 04:32 PM
projectTeG's Avatar
hey are the gear select mechanisms the smae between the b trannies? i got a extra one thats cracked at the base.
Old Dec 5, 2009 | 06:01 PM
Aquafina's Avatar
Yes. Not sure about hydro and cable (I've never compared) but model doesn't matter.
Old Dec 6, 2009 | 06:23 AM
projectTeG's Avatar
k good because the base part where the 3 bolts bolt it down its cracked. i test fit it the tranny works. i just want to replace it with a working part.
Old Dec 6, 2009 | 06:50 AM
projectTeG's Avatar
ok, say i cant find a replacement, i know how to weld cast and tempered metals, would it be ok to weld the crack or braze it shut? and grind smooth?
Old Dec 6, 2009 | 12:04 PM
Aquafina's Avatar
No. Order a new one from Honda.
Old Dec 6, 2009 | 03:39 PM
projectTeG's Avatar
got one already
Old Dec 7, 2009 | 09:52 PM
projectTeG's Avatar
updates, done, driving no high rpm grinds!!!!
tomorrow i crack my Y1 tranny that popped out of 2nd and 3rd and see what is broke.
Andrew77
Nov 14, 2007 03:21 PM
WolfGod
12
Jun 25, 2006 01:36 PM
Yambor
Feb 26, 2004 01:20 PM
Xumarius
Jul 31, 2003 07:45 PM
Juantay19
Apr 5, 2002 04:37 AM
