Transmission & Drivetrain Gearboxes, Differentials, Clutches
broken gsr casing
Old Oct 22, 2009 | 12:20 PM
ayos ctr_hatch's Avatar
Default broken gsr casing
Would all the gsr internal fit in a ls case? Anything I shoul look out for?
Old Oct 22, 2009 | 12:29 PM
night's Avatar
Default Re: broken gsr casing
everything i know about it says it will work. i have a 92 LS trans with a GSR 4.4 and ITR LSD.
all 92+ are the same internally.
Old Oct 22, 2009 | 12:56 PM
Aquafina's Avatar
Diff bearings won't. Must use GSR forks if you use the GSR gears.
Old Oct 22, 2009 | 05:10 PM
So I have to use ls diff bearings and are you talking about the clutch fork?
Old Oct 22, 2009 | 05:35 PM
night's Avatar
are you sure you are up to this?
Old Oct 22, 2009 | 06:16 PM
Aquafina's Avatar
If you use LS diff bearings you have to get creative, not something for someone who doesn't build trannys. Shift fork.
Old Oct 22, 2009 | 07:04 PM
Thanks, so basically I can use all the gsr internals?
Old Oct 22, 2009 | 07:08 PM
Aquafina's Avatar
Yeah. But the diff bearings won't. You'll need to swap the shims and outer races then reshim if you want to use the GSR diff and bearings (assuming it still has the tapered bearings). If you want to switch over to the enclosed bearings you'll need to order new enclosed bearings for a GSR/ITR and reshim the diff.
carlos8
Jun 13, 2015 11:22 AM
raverx3m
21
Dec 13, 2014 11:46 AM
4g hatch
Mar 12, 2014 12:48 PM
quickspool
Mar 17, 2011 08:18 AM
b20vtech
Apr 27, 2006 08:30 AM
