d series shift forks
are dx and si cable trannys shift forks interchangable? i have a couple si trannys with broken shift forks and a spare dx tranny wondering if i can just swap the forks?
Seagull Management
Re: d series shift forks
They should be, they hydro trannys you can as long as you stay within the same years ('92 - '95 and '96 - '00) I don't see why the older cable trannys would be any different.
D Tranny Guru
Thankfully, shift forks for D's are interchangeable within their model years.
88-91, 92-95, or 96-00 will always work in same generation of tranny.
I am a licenced tech and Ive had 26 Hondas. Ive worked on nothing but Hondas for approx 6 years. Ive built b-series trannies, and everything from high comp b-series engines to mini-me's. I currently have a Genuine EF9 Civic which I assisted in importing last year. I have never been able to get a d-series case to bolt back together without jamming the input shaft solid. Ive tried on multiple d-series transmissions using different techniques and parts and have even had the assistance of two Certified Honda Technicians at one point. These are throw away transmissions-dont waste your time, I spent over 10 hours on one d-series transmission in a professional shop, fully equipped with all required tools trying to put the case back together without jamming the input shaft, unsuccessfully.
Seagull Management
X2
That goes to show you just because you have a patch (ASE) on your shoulder, you do not know everything
D Tranny Guru
maritime_ef
03-29-2011 07:10 AM
fastludeh22
04-08-2004 07:01 AM
