Lighting HID/Xenon kits, Retrofits and Associated Topics
foglight ?
Old Apr 2, 2010 | 08:23 PM
jdmsir4dr's Avatar
Default foglight ?
i just recived some yellow fog light i ordered online for my eg4dr but there not as bright as i would like dem to be is there any way to make dem brighter than wat they are
Old Apr 3, 2010 | 06:10 PM
COIntegra's Avatar
Default Re: foglight ?
Hey whats going on....
What you need to do is find out what kinda bulb that you have H3 or whatever. You can go on to the DDM HID kits.
You can just put HID's into your fog light....
If you need help let me know be more then happy to help you.
Old Apr 4, 2010 | 07:41 AM
jdmsir4dr's Avatar
well i havent taking dem apart to find out wat light bulb it is ..but there yellow eg4dr fog lights from ebay
Old Apr 5, 2010 | 07:14 PM
COIntegra's Avatar
I bet they take h3 bulbs and you can put HID ones in there.
Old Apr 5, 2010 | 09:12 PM
miloi's Avatar
TRIAL USER
There is another way to make it brighter.. You need to take out the fog lights from the harness.. There is an eyelids inside of the fog lights.. In order to disassemble it.. you need to have a vise grip or a butterfly allen wrench.. Then inside of it.. There are 3 layers of it.. You will be able to see inside of the fog lights that there is a divider that is attached inside of it that makes the lighting in half.. You will just need to remove it and assemble it again without the eyelids.. Im sure you will be satisfied with it..
I am personally using HID h3 bulbs for fog lights on my eg95.. But you will make a hole under the fog lights and seal it up with sealant..
Old Apr 6, 2010 | 04:09 PM
jdmsir4dr's Avatar
i took off the eye lip but i want it brigther were did u order the hid h3 from
MILANO_RED_CL9
Acura TSX
Dec 8, 2010 05:01 AM
Mr. H_Twizzle
Oct 12, 2010 06:41 PM
S1n1SteR
Jun 21, 2008 12:59 AM
