Lighting HID/Xenon kits, Retrofits and Associated Topics
Interior Lighting
Old Jun 20, 2010 | 07:37 PM
htsang07's Avatar
Default Interior Lighting
Hey, I was wondering if anyone would know if LEDs produce enough heat to melt the housing because I read somewhere that it does. I am planning to install LEDs in the interior (Dome light, Map light, and the door step light).
Thanks.
Old Jun 21, 2010 | 06:01 AM
MrLeWayne's Avatar
Default Re: Interior Lighting
Not in my experience.
Old Jun 21, 2010 | 06:05 AM
ohsnapzafingcu's Avatar
I serve phở for my babies
LED's light much much cooler then regular interior bulbs, they draw less power as well. and last way longer!
Old Jun 21, 2010 | 12:51 PM
htsang07's Avatar
Thanks for the responses. But the thing is, I'm replacing my Dome light (DE3175 bulb) with LEDs (30 LEDs on the circuit) and i was a little bothered about whether or not 30 LEDs together would be too hot. Or perhaps, should I just buy another with less LEDs?
Thanks.
Old Jun 21, 2010 | 03:58 PM
MrLeWayne's Avatar
30LED's? Why?
Old Jun 21, 2010 | 07:01 PM
htsang07's Avatar
It came like that and I guess I bought it cause I thought it would be brighter (it's also on sale) not thinking about whether or not it emits a large quantity of heat.. =(
These are the ones i bought: http://www.v-leds.com/Interior-LED/D...-p5168719.html
Old Jun 22, 2010 | 10:52 AM
htsang07's Avatar
So do you guys think I'm okay with the 30 LEDs or should i perhaps get less (for the dome light)? thanks a lot
Old Jun 22, 2010 | 10:55 AM
GhettoBizzle's Avatar
Youre good.
Prolly stays cool enough to touch after an hour of use
Old Jun 22, 2010 | 10:57 AM
Duane_in_Japan's Avatar
They do make very bright LED's these days, I have not looked around but Google may come up with something better, not that your idea is bad. I would want to see one in action before getting it, 30 light to make the same brightness as one old little bulb, maybe a little brighter???
Old Jun 22, 2010 | 02:21 PM
jughead's Avatar
yeah post some pics once you get these in
Old Jun 23, 2010 | 05:34 AM
operatic's Avatar
The only LED I would be concerned about are the high power style bulbs that have a metallic heatsink built into the base. Something like this:
http://badablinghids.ecrater.com/p/7...-panel-12-watt
Those guys will generate a good amount of heat. Everything else I've ever used though (1210 SMD, 5050 SMD, flux, LED) do not create enough heat to be worried about.
Old Jun 23, 2010 | 08:49 AM
MrLeWayne's Avatar
I would also like to see pictures posted upon completion.
Old Jun 24, 2010 | 10:23 PM
htsang07's Avatar
Yeah, I will post up some pics after i put them in, I just ordered them a few days ago, they SHOULD arrive by next week.
But about what OPERATIC said kind of scares me a little because I also bought this :
http://www.v-leds.com/Interior-LED/D...87987-1-2.html
For my license plate light. It also has a heat sink and because it's on the license plate light it will probably be on ALL day. Do you think there would be a problem with these? I'm sorry, I've been really paranoid and cautious with my car lately since I'm really trying to keep it nice and running well. I particularly do not want to take any chances with melting housings.. I probably should have posted these questions before buying it =(
Please let me know what you guys think about these and heat problems. Thanks a lot!
Old Jun 25, 2010 | 06:26 PM
htsang07's Avatar
Anyone have any suggestions or any experience with these? Or just anything to add..?
Thanks
Old Jun 27, 2010 | 06:18 AM
operatic's Avatar
That particular style, I haven't seen. Typically the high power bulbs I see are a single LED on top, of varying wattage. The ones I've seen in person, hold up fine. The V-LED ones, I cannot personally comment on because I've never tried them. You should not have a problem with it though.
The only thing I would be worried about, is if it fits your license plate housing. It's hard to tell from the picture, but it looks a little on the tall side and looks like it's on a PCB board. The height may be an issue.
Nine3Sol
Feb 18, 2019 04:12 PM
360infinite-usa
319
Dec 20, 2011 07:30 PM
PunkRudeBoy
Jan 9, 2011 07:22 AM
mckenzie
Honda S2000
Dec 6, 2006 01:34 PM
