Lighting HID/Xenon kits, Retrofits and Associated Topics
HELP!
Old Mar 15, 2010 | 07:52 PM
92_JDM's Avatar
Default HELP!
I want to know how to make the corner lights of my DA blink the same time as the signal light at the bottom..
Need as much help as possible thank you
Old Mar 16, 2010 | 05:09 PM
98civdx's Avatar
Master Detailer
Default Re: HELP!
wire them to the turn signel wires. easy to do.
Old Mar 17, 2010 | 12:58 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: HELP!
You can tap them directly off of the turn signal, but then they will not come on with the tail lights to serve as your front parking/clearance/marker lights. You could get pulled over and ticketed and/or not pass inspection.
The way they're wired stock, they should blink with the turn signals when your parking lights are off. When parking lights are on, they should blink opposite your turn signals.
Old Mar 17, 2010 | 08:23 PM
92_JDM's Avatar
Default Re: HELP!
thanks a lot.
really appreciate your help.
my_gsr_teg
May 4, 2009 11:01 PM
my_gsr_teg
Apr 27, 2008 03:09 PM
Pandahatch
11
Dec 8, 2004 01:49 PM
N33dsp33d
Aug 24, 2004 04:57 PM
