Lighting HID/Xenon kits, Retrofits and Associated Topics
Too many things hooked up to a fuse?
Old Mar 17, 2010 | 05:40 PM
andrewtheaccord's Avatar
Default Too many things hooked up to a fuse?
I have my under dash led's hooked up to my interior lighting fuse. I just have 2, 9 inch led strips.
I'm adding 2 more strips to my back seats hopefully tomorrow, and would like to hook them up to the same switch as my front led's.
But I was wondering, if I added 2 more strips, would it pop my fuse? or should it be okay?
Thanks!
Andrew
Old Mar 17, 2010 | 06:02 PM
Weakbyyou's Avatar
Default Re: Too many things hooked up to a fuse?
LED's dont draw much power but if you have an issue blowing fuses and you have them on a switch anyway why dont you run power straight to your constant at the ignition switch or right to your battery. if you want them to come on with your interior lights use a relay.
Old Mar 17, 2010 | 08:11 PM
I wanted a relay but couldn't find it, I made a post here but no response.
I'll mess with it tomorrow when I install the lights. I figured it wouldn't bother it cause of the led power usage, but i just wanted to make sure
Old Mar 19, 2010 | 05:33 PM
Weakbyyou's Avatar
what do you mean you couldnt find it? you would have to get one and wire it up
Leviatard
Mar 27, 2014 06:37 AM
acracer2008
Nov 1, 2010 11:14 AM
dwerpk
Jan 16, 2008 01:59 PM
CooBreeze
Oct 19, 2007 05:53 PM
92wraith
Oct 12, 2005 06:31 PM
