Lighting HID/Xenon kits, Retrofits and Associated Topics
HID's with daytime running lights?
Old Mar 25, 2010 | 11:51 AM
smokinloc's Avatar
Default HID's with daytime running lights?
hey im getting a set of low beam HID's for my 1993 civic, the car has stock headlights and bulbs, it came with daytime running lights stock. i have been reading online and people say if your are going to use low beam HID's to remove the DRL but i cant find out how to do that on an EG civic, can anyone point me in the right direction?
Old Mar 25, 2010 | 03:39 PM
TunerN00b's Avatar
Default Re: HID's with daytime running lights?
Pull the DRL fuse.
You probably wn't get too many replies, as the US Civic didn't have DRLs (only the Canadian one to my knowledge).
Old Mar 26, 2010 | 07:43 AM
e46civic's Avatar
Im pretty sure there is a circuit board also.
Old Mar 26, 2010 | 01:03 PM
smokinloc's Avatar
mhmm alrite well ive been looking thru my haynes manuel and it says nothing about it. a friend of mine suggested that maybe i just disconnect the wire going to the e brake so it doesnt know when the DRL should be on? any help would be much appreciated!
Old Mar 27, 2010 | 12:32 PM
e46civic's Avatar
Get a Helms manual, haynes are junk. What would the ebrake have anything to do with it?
Old Mar 27, 2010 | 01:52 PM
smokinloc's Avatar
i figured out wich fuse it was, and the DRLs dont come on unless u release the ebrake so he thought that maybe some of the wires goin to the ebrake were for that.
Old Mar 27, 2010 | 06:00 PM
e46civic's Avatar
Weird, I use the spot on the switch that Helms says is for DRL. The low beam stays on with the high beam. If I had the book nearby Id look for you. I cant remember if it shows both US and Canadian, or if there is just a note about the DRL in Canada.
Old Mar 29, 2010 | 07:22 PM
Huss's Avatar
What fuse it was?
Old Mar 29, 2010 | 07:23 PM
smokinloc's Avatar
it was a 7.5 fuse in the fuse box below the steering wheel....i think its 16 or 15 or somin
Old Mar 29, 2010 | 08:07 PM
Huss's Avatar
i wonder if its the same on my 99 sir, what is the spec for the kit? bulb size etcc... i am looking for 6000k
OregonDucks
Honda Civic (2001 - 2005)
Dec 24, 2017 10:42 AM
smokinloc
Mar 26, 2010 12:58 PM
stormtdog
Honda Fit
Sep 12, 2008 01:42 AM
KrazyDawg
17
Mar 18, 2008 10:31 PM
hdeucedeuce.cd7
Aug 30, 2003 11:05 AM
