Lighting HID/Xenon kits, Retrofits and Associated Topics
hid strobe lights
Old Apr 13, 2010 | 04:09 PM
lostkoz's Avatar
Default hid strobe lights
i have a jdm type r front end had it for years now. just recently came across some jdm hid lights wired them in accordingly all turns on like needs to. day light running then low and high all works. have not figured out the turnning signals yet. now my low beams went to a strobe light. only thing i can think of was not having the car on. they came back on after i shut them off. so they almost shot or the car needs to be running any thoughts.
Old Apr 14, 2010 | 08:18 PM
prelude1897's Avatar
Default Re: hid strobe lights
so you have HIDs correct and the lights will flicker when turning on? Sounds like your ballast is about to go out on you or you need to check your wiring again
Old Apr 18, 2010 | 05:27 PM
chawski's Avatar
youre not getting 12 volts to the ballasts. you need to make a wire harness off the battery. the stock cables cant handle the startup draw
Old Apr 25, 2010 | 04:16 PM
lostkoz's Avatar
my bat went dead from all the testing. once i jumped the car and it was runnung. i tested them with the car runnung all stayed on. guess ill see one night if the ballast does go out.
batto24GSR
Oct 16, 2012 10:38 AM
ef9robert
Nov 16, 2008 05:38 AM
nikech1
Sep 6, 2007 05:33 PM
jDm t3g
Mar 17, 2003 05:07 PM
STC
Jul 23, 2002 12:22 AM
