88-91 CRX/EF Civic Frequently Asked Questions (FAQs)
Please PM a moderator if a link doesn't work or if a link should be added to this thread.
* = non-Honda-Tech link
1. General information and resources
2. OEM Honda/Acura online parts dealers
7. Engine swaps and conversions
15. Climate control
1st, 2nd, 3rd, and 5th Generation Civics
- What does CRX stand for?
- Differences among CRXs
- *US 1991 CRX new car brochure
- EF, ED, HF, DX, Si, etc. definitions
- Civic chassis codes
- Fourth generation CRX/Civic specs
- VIN explained
- 88-91 factory color chart with pictures
- All Honda car stock weights
- Jacking points - where to put a jack
- Honda screws and JDM screwdrivers
- *Ben Ogle's EF resource tech page
- *Wes Vann's EF Honda page
- *FAQ.ef-honda.com/
3. Vehicle security4. RHD conversion5. ECU, codes, and tuning
a. Identification, part numbers, CEL codes and troubleshooting, pin outs
6. Engine- ECU information
- Identifying ECUs
- *ECU identification
- Honda/Acura ECU part number list
- OBD0 CEL codes
- ECU CEL codes and troubleshooting
- ECU CEL codes
- ECU pin outs
- Repinning an ECU
a. General
b. Common problems, diagnostics, treatments
c. Ignition system
d. Fuel system
h. Intake, vacuum, idle control
i. Header and exhaust
j. Emissions
k. The D-series engine
- SOHC upgrades - ongoing information
- Installation of camshaft into a sohc
- SOHC cam specs
- SOHC camshaft and valve springs install
- Spades huge SOHC upgrades thread
- SOHC upgrades revised - long work in progress
- D-series piston pictures
- Hasport D-series replacement mounts and hydro conversion
- Innovative D-series replacement mounts and hydro conversion
- ZC means 1.6L D Series
l. The B-series engine
- How To - identify B16A1 and B16A2 engines
- *Identifying first and second generation B16A engines
- B16 secondary O2 sensor
- B16A secondary O2 sensor wiring and vacuum diagrams
- Block guard
- ITR/ITR-style header on B-Series
- Replacing CRX JDM B16 VTEC solenoid gasket
- B16 parts list
- B-series torque spec list
a. General
b. OBD0-to-OBD1 conversion
- OBD0 to OBD1 conversion pinouts
- OBD0 to OBD1 pinouts and conversion
- How-To - swap/remove OBD1 injector pins
- DPFI-MPFI swap information
- *DX, STD (DPFI), Si, HX -- MPFI wiring
- *Plugs needed to swap d15z1 into MPFI Civic/CRX
e. DOHC ZC swap
g. H-series swap
h. K-series swap
8. Forced induction9. Transmissiona. General information
c. Removal, disassembly, rebuild
e. Auto-to-manual conversion
f. Four-wheel drive
10. Axle11. Brakes- How To - identify Si, DX and HF L3 transmission
- ZC L3 transmission information
- *Notes about JDM L3 (DOHC) "ZC tranny"
- *CRX math - tranny calculator
- Removing D-Series transmissions in a CRX
- How To - remove transmission and inspect input shaft bearing
- *CRX transmission rebuild
- *CRX HF transmission rebuild
- LS 5th-gear install guide JDM B16 S1
- LSD - toss tapered bearings and install ball bearings, no preload
- B-series transmission and clutch guide
f. Four-wheel drive
a. General
c. Upgrade
12. Suspension- Four-door brake swap
- How To: Rebuild brake calipers
- Brake rotor replacement
- Brake booster and master cylinder interchangeability
- Putting X brakes on Y car
c. Upgrade
a. General
b. Front
d. Coilovers, sway and traction bars, tie brace, camber kit, Energy suspension
13. Steering rack and steering wheelb. Front
- Civic/crx JDM B16 knuckle comparison to DA, and US EF
- How to distinguish EF knuckles
- *1990-91 Civic sedan EX hub replacement/interchange
- How To - pop off a ball joint (videos)
- How To - install wheel bearings/lower ball joints - pictures
- How To- replace wheel bearing
- Tie rod end removal
- Changing tie rod ends
- Front tower bar install
- Coilover sleeve install
- Sway bar sizes
- Best traction bars
- Lower tie brace install
- Progress camber kit install
- Energy suspension Hyperflex polyurethane bushing instructions and parts list
- Rear trailing arm part number
- Trailing arm identification
- DA rear sway bar on DX
- The old washer method for the rears
- Rear positive camber washer trick
- Rear compensator (toe) arm nut fix
- Rear lower tie brace install
14. Wheels
15. Climate control
16. Interior
a. Door panel, seats, seat belts, paint removal
17. Exterior- How To - remove CRX door panel
- How To - install a footrest
- Answers to a lot of seat questions
- Seat swap
- Seat pan swap: 90/91 Si HB seats into 88 HB and vice versa
- Head rest removal on CRX Si seats
- Little info about seat pan swapping
- Seat belt swap
- Removing paint from interior
a. Rust repair, paint, fiberglass
18. Electrical- Prepping car for paint
- Painting your car -- tips, tools and techniques
- Painting body trim
- Painting door handles and mirrors
- Painting exterior trim pieces
- How To - use fiberglass
- Interchangeable EF Hoods by part numbers
- How To - remove CRX door sill
- Home Depot lip
- CRX rear Lip
- Lips and side skirts
- How To - homemade air splitters/canards
- Reskin roof & permanent sunroof removal
- Sunroof switch sticks
- How To - refurbish sunroof switch
- Civic Hatch and Sedan Front Bumper Differences Explained
a. Fuse box, ignition switch, battery relocation, alternator
e. Exterior lighting, warning beeper
---------------------------------------------------------- CRX fuse boxes
- Ignition switch replacement
- How To - relocate battery to trunk
- How to - remove/rebuild/test the CRX alternator
- How To - install power windows in a CRX
- *Honda/Acura stereo wiring diagram
- Dome light fix
- JDM map light dimensions
- How To - add intermittent wipers to 88-91 civic hatchback
- 4G Civic Cruise Control retrofit DIY
- Si to HF engine harness
- Si to ZC wire diagram
- Wire tuck
- Wire tuck
- Wire tuck - relocate fusebox and headlight wiring
- Installing JDM amber dash and clock
- Manual transmission cluster into auto car
- Euro VTI cluster in 89-91 Civic/CRX
- 99-00 Si gauge cluster into 88/89 Civic/CRX with wiring
- How To - Integra gauges into 88-91 Civic
- GSR cluster into 90-91 CRX with pinouts
- S2000 cluster swap
- S2000 cluster pin outs
- Set odometer to correct mileage
- Brake lights won't turn off even without key in ignition
- How To - put Acura TL HID's into EF headlights
- OEM HID's into 9006 housing
- How To - install JDM EF8 CRX sidemarkers
- JDM CRX sidemarker write up
- How To - JDM fog lights on USDM Car
- How To - simple headlight warning beeper
- How To - tint headlights
Care to add a link to this 4G Civic Cruise Control retrofit DIY?
https://honda-tech.com/forums/showthread.php?t=2824711
This wheel bearing replacement How To should be included as it doesn't require a press like the others in your line-up.
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/write-up-diy-front-wheel-bearing-replacement-2685054/
I have also made an engine storage one as well...
I have a question regarding my coolant temp sensor. my 91 crx has a sensor with two wires but the wiring harness was swapped with one from a newer civic. thos sensors only have one wire. how do i solve this problem?
Hello there! This list is sooooo helpful! Thank you so much!
One thing though, the auto-to-manual transmission conversion link seems to be redirecting to a gas mileage site? I'm pretty sure that's not right, but would anyone be able to redirect me to a link regarding this how-to? Thanks! :D
How about adding the TPS thread
https://honda-tech.com/forums/honda-...hread-2830131/
hey im trying to find a b16a with a cable trans for my 90 civic i have found a few places but dont know if they are legit if you guys can let me know where you guys have gotten yours that would be great thanks again
So I know you put it down but when I went to the page it took me to some random website without the information,
i have a b18b1 engine in my 89 crx , it needs to be tuned. The guy before me unfortunately didn’t do it which makes no sense , what kinda chips / anything really would you recommend. ( sorry new to this)
Please Tell me anyone
I am stuck in my HONDA CIVIC 89 Dome light is not working i change the Light and Fuse But Still Not Working .
Even I didn't find wiring and connector its behind the dashboard.
Please help Me........anyone
Get yourself the Haynes manual (Chilton sucks for wiring) and a good DMM and make one of the leads about 8 feet long with an alligator clip on it and start chasing wires. It won't take you long to figure it out there's only 2 wires involved.
Hi. Anyone have diagram or foto of civic ec9 dualcarb gauge cluster wireing? I buy dash for injection models and need to rewire, but wireing on my civic is different from fotos that I found here. Thaks in advance and sorry for bad english.
GeoMetry
Jul 13, 2013 08:52 AM
Former User
131
Jan 7, 2013 04:14 PM
