#2 |
Lots of how-to's..
Fourthgenhatch.com <- helms-oilchange, mirror, scanner, Discchanger, emissions, rollbar, tegraconsole, helms-ecucodes, keylessentry, axle, tegmp, jdmfoldingmirrors, paintingbumpers, cat, distro, howto, headlightbuzzer, taillights, batterytiedown, mpfi, helms-bodyspecs, wheelstud, zc, trannyfill, hubcaps, cai, engineclean, battery, mainrelay, reardiscswap, helms-engineremoval, sedanhandles, sigaugecluster, ac, helms-bumpers, brakebleeding, helms-fuelfilter, 9005 Headlight Conversion make your low beams brighter for better night vision, Auto2Manual Swap C-speedracing.com FAQ.ef-honda.com/ D16Y8 intake manifold onto D16a6 engine Modified by Mr.speaker at 8:43 AM 1/30/2006 |
#3 |
this was taken mostly from the previous faq, which i tried to get posted at the beginning of the original faq but to no ,luck .... oh well.... anyways i tried to remove all the dead links, so they should all be working, sorry if theres repeate stuff.
General http://hondainfo.freeweb.hu/menu30-11.html - Crx Specs http://honda-tech.com/zerothread?id=1024595 - A list of known part numbers for commonly replaced parts http://honda-tech.com/zerothread?id=1016891 – SeaFoam http://www.honda-tech.com/zerothread?id=1059690 - SeaFoam http://www.pgmfi.org/ - Information on chipping honda ECUs http://www.xenocron.com/te.php?page=ECUlist - ECU part number list for Honda/Acura http://www.honda-tech.com/zerothread?id=1250708 - List of places to get parts from http://www.honda-tech.com/zerothread?id=1202591 - Airflow velocity for different intercooler piping diameters (2.0 2.25 2.5 2.75 3.0 inches) http://www.4guk.co.uk/forum/ - 4th Gen Info http://public.fotki.com/CRX/car_pics_by_chasis/efs/ - crx photos more then you can think of, its just for jdm lovers http://www.geocities.com/speed...o.htm - speedphreak knows his stuff. dsm injector install, mech water temp sender install, power windows, oil pressure sender how to, daytime running lights how to, 88-00 si cluster swap how to... ect.... http://www.hondata.com/techecuid.html - all the ECU info you've ever wanted to know! http://www.stefanoparis.com/cr....html - 1991 CR-X Dealership Brochure! Complete and in JPEG Format!! http://www.manhonda.com/ap/index.cfm?level=69&PG=0 - Manchester Honda online parts http://www.evotuners.com/hondafaq.htm - The VERY old but still useful original "Honda Performance FAQ" http://kumo.swcp.com/synth/crx/analysis-care.html - 84-87 CRX Analysis & Care / Pros & Cons http://kumo.swcp.com/synth/crx/specs.html - 84-87 CRX Specs & Performance http://honda-tech.com/zerothread?id=650219 - Differences in 2nd Generation CRXs http://www.honda-tech.com/zerothread?id=637990 - How to Use Fiberglass http://www.c-speedracing.com/faq/06.php - How to Check ECU / Engine Codes http://www.honda-tech.com/zerothread?id=468260 - EF ECU Codes and Troubleshooting http://asia.vtec.net/spfeature/vtecimpl/vtec1.html - How VTEC Works http://asia.vtec.net/topics/b16aver.html - How to Identify B16A1 and B16A2 http://www.hmotorsonline.com - Hmotorsports Online Engine Shop http://www.honda-tech.com/zerothread?id=648939 - want to pass REF ^!!! http://honda-tech.com/zerothread?id=411318 - how rt4wd works http://www.honda-tech.com/zero...56615 - stock honda car weights http://www.team-integra.net/se...eID=4 - FLow velocity http://www.homemadeturbo.com/f...=3921 - Turbo Info http://www.honda-tech.com/zerothread?id=1261154 - Best Place to Buy JDM Engine / Motor / Swap Interior http://honda-tech.com/zerothread?id=598255 – Removing Paint from Interior http://www.coe.uncc.edu/~mdkeena/plate/ - If your CRX climate control has cracks in it here is a full write up on how to fix it http://honda-tech.com/zerothread?id=1062869 - Seat Pan Swap: 90/91 Si HB Seats in 88 HB & Vice Versa http://www.honda-tech.com/zerothread?id=988203 - Answers to alot of seat questions http://www.honda-tech.com/zerothread?id=1070216 - Set your Odometer to the correct mileage! http://www.ef-honda.com/main/viewtopic.php?t=1400 - 3gen GSR/99-00 SI gauge cluster install with 88/89 civic/crx wiring ALSO!!!! http://www.honda-tech.com/zerothread?id=347548 - little info about seat pan swapping. It gives you a general idea http://www.honda-tech.com/zero...age=1 - integra console in a 90 hb lots of pics http://b16a.honda-perf.org/cluster.html - SiR cluster how to http://www.angelfire.com/ca/DrOhm/SiRcluster.html - EURO VTI cluster in 89-91 civic/CRX http://www.honda-tech.com/zerothread?id=735810 - How to Remove CRX Door Panel (56K Problem) http://www.honda-tech.com/zerothread?id=735808 - How to Remove CRX / Civic Steering Wheel http://www.geocities.com/Motor....html - 4th Generation Civic SiR Gauge Cluster Installation http://www.honda-tech.com/zerothread?id=1499527 - Do it yourself: jDM y0! Amber Dash and clock! Exterior http://www.honda-tech.com/zerothread?id=1218089 - HOW TO: Refirbish your sunroof switch to make it fully functional again! http://honda-tech.com/zerothread?id=640755 – Painting Valve Cover http://honda-tech.com/zerothread?id=782937 – Painting Valve Cover http://www.honda-tech.com/zerothread?id=491789 – Painting Valve Cover http://www.honda-tech.com/zerothread?id=476935 – Prepping Car for Paint http://www.honda-tech.com/zerothread?id=542359 – Prepping Car for Paint http://www.honda-tech.com/zerothread?id=376870 – Painting Your Car, Tips, Tools and Techniques http://www.honda-tech.com/zerothread?id=965005 – Painted Door Handles and Mirrors http://honda-tech.com/zerothread?id=489625 – Painting Exterior Trim Pieces http://www.honda-tech.com/zerothread?id=316500 – Painting Wheels http://honda-tech.com/zerothread?id=1130443 - DIY polishing HX and VX rims http://www.honda-tech.com/zerothread?id=1060330 - How to: JDM Fogs on USDM Car http://www.honda-tech.com/zerothread?id=964126 - Home Depot DIY Lip http://www.honda-tech.com/zerothread?id=735811 - How to Remove CRX Door Sill (56K Death) http://www.honda-tech.com/zerothread?id=435285 - How to Make Homemade Air Splitters / Canards http://www33.brinkster.com/mikehiggins/crxsunroof.html - How to Rebuild Your Sunroof (Adobe PDF) http://www.honda-tech.com/zerothread?id=447086 - How to put Acura TL HID's into EF headlights http://honda-tech.com/zeropost?cmd=tshow&id=742906 - rebuilding your sunroof http://tuner-junction.com/TJForum/showthread.php?t=2307 - How to install JDM EF8 CRX Sidemarkers Engine & Transmission http://honda-tech.com/zerothread?id=1193782 - b16a crx si swap guide http://honda-tech.com/zerothread?id=1052937 - 1988 and 1991 Si vacuum diagram http://honda-tech.com/zerothread?id=1325930 - Changing transmission fluid,Lubricating speedometer cable and reconnection of cable at the transmission http://honda-tech.com/zerothread?id=1360901 - Honda Engine Code Chart http://www.honda-tech.com/zerothread?id=335078 – Spades Huge SOHC Upgrades Thread http://honda-tech.com/zerothread?id=382416 - B Series Axle Replacement http://www.honda-tech.com/zerothread?id=596873 – D Series Transmission Disassembly and Input Shaft http://honda-tech.com/zerothread?id=864710 – SOHC Camshaft and Valve Springs Install http://honda-tech.com/zerothread?id=363047 – VTEC Cams Comparison http://www.honda-tech.com/zerothread?id=684550 – H22 vs B Series Weight http://www.honda-tech.com/zerothread?id=682485 – Engine Compression Ratio Formulas http://honda-tech.com/zerothread?id=694733 – Civic Chassis Codes http://honda-tech.com/zerothread?id=466327 – Removing Engine Without Hoist http://www.honda-tech.com/zerothread?id=1263692 - how-to install a Walbro HP 255 lph fuel pump into a CRX http://www.honda-tech.com/zerothread?id=1230434 - B&M Fuel pressure modifier install How-To http://www.honda-tech.com/zerothread?id=1157746 - EF CRX/Hatch B series turbo shopping list (BlueShadow's turbo project) http://allmotorhonda.com/techp...s.htm - B series tranny specs http://web.archive.org/web/200...s.htm - Great axle info that no longer exist unless using the right website http://coreyonline.tripod.com/crxmainpage.html - B16 swap into first generation CRX http://www.geocities.com/senpa....html - D16A6 / D16Y8 mini-me http://www.geocities.com/senpa....html - Transmission Removal http://www.geocities.com/senpa....html - Clutch Install http://www.angelfire.com/ca/Dr....html - B16 Dizzy diy repair http://www.geocities.com/neonradiator/neon.html - Dodge Neon Radiator upgrade (yes the neon is good for something) http://www.c-speedracing.com/h...m.php - DOHC cam swap how-to http://www.honda-tech.com/zerothread?id=953151 - B series Torque Specs List http://www.honda-tech.com/zerothread?id=953089 - shopping list of nuts, bolts, and other stuff needed for the swap http://honda-tech.com/zerothread?id=939636 - Removing D-Series Transmissions in CRXs' http://honda-tech.com/zerothread?id=945557 - where everything plugs into the motor on a MPFI harness http://www.honda-tech.com/zerothread?id=427814 - SOHC Cam Specs http://crx.honda-perf.org/arti....html - Mini-me engine theory http://www.knology.net/~jediklc/D.htm - Compression calculator http://honda-tech.com/zerothread?id=699787 - How to fix a FITV its as easy as 1, 2, 3 http://honda-tech.com/zerothread?id=750674 - installation of camshaft into a sohc http://www.angelfire.com/on4/crxpage/shift.html - Fixing Sloppy Shifting in Transmission http://www.honda-tech.com/zerothread?id=555929 - LS 5th Gear Install Guide JDM B16 S1 http://www.honda-tech.com/zerothread?id=90743 - Camshaft Test http://www.honda-tech.com/zerothread?id=382416 - Axel Replacement http://tjshondas.20m.com/l3.htm - ZC L3 Transmission Information http://www.honda-tech.com/zerothread?id=335078 - SOHC Upgrades (Ongoing Information) http://www.angelfire.com/d20/h....html - DPFI to MPFI Fuel Injector Swap Guide #1 http://www.geocities.com/teampimports/fuelinj.html - DPFI to MPFI Fuel Injector Swap Guide #2 http://www.geocities.com/c_rexboy/mpfi.html - DPFI to MPFI Fuel Injector Swap Guide #3 http://www.bladesilver.net/crx/projects.html - DPFI to MPFI Fuel Injector Swap Guide #4 http://www.fourthgenhatch.com/mpfi.html - DPFI to MPFI Fuel Injector Swap Guide #5 http://honda-tech.com/zerothread?id=404493&page=1 - B16A Secondary o2 Sensor Wiring and Vacuum Diagrams http://www.geocities.com/bing_bong916/vtec.html - More Information On Swapping D16Z6 into an EF http://crx.honda-perf.org/arti....html - How to Swap a Z6 Head Onto Your A6 http://b16a.honda-perf.org/theswap.html - JDM B16A Information and 4th Generation ECU Pin Outs http://honda-tech.com/zerothread?id=717258 - B16 Swap info http://www.honda-tech.com/zerothread?id=692814 - LSD....toss your tapered bearings and install the ball bearings, no preload http://honda-tech.com/zerothread?id=177711#1593432 - Sonnys compression spreadsheet http://www.norcalcrx.org/dropp...p.htm - B16 Install Info (Thanks Ryan Droppedcrxsi) http://www.thezcr.com/forums/a...=1137 - Si to Zc Wiring Diagram http://thenew.gamesbbs.com/~dmoore/zc.htm - Zc Swap Info http://thezcr.com/forums/ - Alot of Zc Info http://www.honda-tech.com/zerothread?id=1108908 - Abit of H22 Info http://sportcompactcarweb.com/...ifter/ - H22 Shifter into Crx http://www.honda-tech.com/zerothread/1290733 -H2B Adapter (H22 motor with B-series Transmission) The N1 CTR pulley uses a 4 rib 735mm belt. A 92-94 Acura Vigor power steering belt fits, part number 56992-PV0-013 A 90 Civic DX tranny weighs 68 lbs Suspension http://www.honda-tech.com/zerothread?id=920087 - Progress Camber Kit Install http://www.honda-tech.com/zero...75861 - how- to install a Full Race traction bar in an EF http://www.rpmnet.com/techart/spring.shtml#rate Very good spring writeup http://www.honda-tech.com/zerothread?id=152884 – Putting X Brakes on Y Car http://www.honda-tech.com/zerothread?id=333061 – Five Lug Conversion http://www.honda-tech.com/zerothread?id=490117 – Tie Rod End Removal http://www.honda-tech.com/zerothread?id=1031874 – Changing Tie Rod Ends http://www.honda-tech.com/zerothread?id=861481 – Rear Lower Tie Brace Install http://www.honda-tech.com/zerothread?id=972851 – Front Tower Bar Install http://www.honda-tech.com/zerothread?id=1079213 – Lower Tie Brace Install http://honda-tech.com/zerothread?id=1078663 – Coilover Sleeve Install http://honda-tech.com/zerothread?id=864784 – Brake Rotor Replacement http://www.angelfire.com/ca/DrOhm/SiRkuckles.html - civic/crx JDM B16 knuckle comparison to DA, and US EF http://www.honda-tech.com/zerothread?id=748238 - ITR SUSPENSION INTO 91 Si (56K warning, lotta pics) http://www.honda-tech.com/zerothread?id=469485 - How to Extend Shock Travel http://honda-tech.com/zerothread?id=330624 - the ol' washer method for the rears http://honda-tech.com/zerothread?id=572765 - How-to on removing steering rack(non-power steering) http://www.honda-tech.com/zerothread?id=1156671 - best traction bars Electrical http://honda-tech.com/zerothread?id=1032246 - how to test your main relay http://www.velocitymotorsport.com/index_main.html - alarm installation help, how a relay works, installing power locks ect.... how to's. click installers domain to access this information. http://bulldogsecurity.com/New...1.htm - alarm wiring location and wire color Civic http://www.bulldogsecurity.com...1.htm - alarm wiring location and wire color CRX http://www.honda-tech.com/zerothread?id=1124908 - Ignition switch replacement http://www.honda-tech.com/zerothread?id=1131532 - how to relocate your battery to your trunk http://honda-tech.com/zerothread?id=1222469 - how to install power windows in a CRX http://www.honda-tech.com/zerothread?id=682412 – ECU Codes http://www.honda-tech.com/zerothread?id=587460 – Repinning an ECU http://www.honda-tech.com/zerothread?id=810101 – Identifying an ECU http://honda-tech.com/zerothread?id=478377 – ECU Pinouts http://honda-tech.com/zerothread?id=418159 – VAFC Wiring Diagrams http://honda-tech.com/zerothread?id=413799 – Hondata Vs. AEM EMS http://www.installdr.com/Harnesses/HA-Wiring.pdf - Stereo wiring diagram Honda/Acura http://www.honda-tech.com/zerothread?id=728372 - OBD0-OBD1 injector pin swapping how-to. No wire cutting-splicing or soldering needed. http://www.honda-tech.com/zerothread?id=735803 - How to Remove / Rebuild / Test CRX Alternators (56K Sorry 2MB in Pics) http://www.honda-tech.com/zerothread?id=651007 - DIY chipping info, including ROM editing, datalogging, and physically chipping ECUs http://www.honda-tech.com/zerothread?id=1297327 - How-to: Fuel Pump Cut Off Switch V-AFC VTEC controller -------> ECU PIN location Red & Orange wire splice/connect to A15 (yellow/black) Green wire RPM signal splice/connect to B15 (white1) Pink wire VTEC signal output to VTEC solenoid (green/yellow) Purple wire VTEC signal input not used on PM6 ecu Blue wire VTM signal not used on PM6 ecu Gray wire Throttle signal splice/connect to C7 (red/blue wire) Yellow wire Pressure signal output cut/connect to C11 ECU side harness Si/Hf = white1 , DX = orange White wire Pressure signal input cut/connect to C11 ENGINE side harness Si/Hf = white1 , DX = orange Black wire Ground splice/connect to A16 (brown/black wire)Engine side harness Brown wire Ground splice/connect to A16 (brown/black wire)has to be connected closer to the ECU Modified by higgunscrx at 8:48 PM 6/10/2006 Modified by higgunscrx at 7:04 PM 9/3/2006 Modified by CRX Toad at 7:34 AM 4/13/2008 |
#4 |
Engine info
http://honda-tech.com/zerothread?id=1556981 FITV fix http://www.honda-tech.com/zerothread?id=699787 Busting lower ball joint http://www.honda-tech.com/zero...age=1 CV splin count http://www.honda-tech.com/zerothread?id=365134 Adjusting tps http://www.integra.orcon.net.nz/tps Auto to manual http://hometown.aol.com/jrmupzaii/auto2man.html Codes http://honda-tech.com/zerothread?id=1558301 Modified by 90blackcrx at 8:03 PM 3/13/2006 Modified by 90blackcrx at 8:06 PM 3/13/2006 |
#5 |
Moderator
If anyone feels they need to add a USEFUL link to this thread, drop me a PM and I will take it from there.
To the people who think they are funny by bumping this thread even though it will stay at the top of the forum since it is a sticky, just ask the others what happened! DO NOT CRY WHEN YOU GET % TAKEN AWAY! |
#6 |
Three Rules of this Thread:
Do not add anything to this thread. (If you would like to add any useful info to this thread, PM CRX Toad or El Vap first.) Do not COMMENT in this thread. (if you think this thread is great, wonderful, we dont need to hear about it or need it bumped, its already stickied and at the top of the forum.) If you have a question, start a new thread. This is not a help request thread. (dont IM me either, i wont answer any technical questions over IM.)
Don't IM me your TECHNICAL question. Start a thread, I'll answer there. FS: Mugen CF-48 13x5.5 -38 Wheels *NIB* FS: 4040 Brake Proportioning Valves |
| Bookmarks |
| Tags |
| 2004, 8891, acura, b16a, cable, capacity, civic, climate, control, crx, diagram, ef, honda, identifying, install, speedometer, transmission, tsx, wiring |
