Lighting HID/Xenon kits, Retrofits and Associated Topics
HID high beam hook up?
Old Mar 1, 2008 | 12:59 PM
rsdriver17's Avatar
Default HID high beam hook up?
i have a set of catty XLR bi exnon and im not sure on the high beam wiring, Theres 4 wires, 2 for the ballas and 2 for the high beam solenoid. read in a thread somewhere that you can burn it up somehow, anyone got any ideas
Old Mar 1, 2008 | 01:32 PM
striker_18's Avatar
Default Re: HID high beam hook up? (rsdriver17)
red wire coming out of the solenoid goes to the positive high beam, black goes to the shared negative.
Positive low beam goes to the ballast, share negative goes to the ballast as well.
Old Mar 1, 2008 | 03:02 PM
rsdriver17's Avatar
Default Re: HID high beam hook up? (striker_18)
i figured that was how it was to be wired, can another person verifi that it is correct so that im 100% on this
Old Mar 1, 2008 | 03:24 PM
striker_18's Avatar
I'd rather use a relay harness with a double relay and a diode going from the high beam section to the low beam. That way, when you have your high beams(shield) activated, you will have power to your low beams. Whenever dual-filament systems, the high beams are activated, there will be no power to the low beams. In a case like that, if there's no diode to give the low beams power, whenever you flash your high beams, your solenoid will be activated but your low beams will turn off thus the ballast will get no power.
Old Mar 2, 2008 | 02:24 PM
rsdriver17's Avatar
Very true, where would i find a relay of the sort, possiably radio shack and what would i be looking for, everyone just says get a relay. Well what type?
Old Mar 3, 2008 | 01:06 AM
striker_18's Avatar
it is a bixenon relay HARNESS to be clear. It isnt just a relay but pretty much a schematic using relays and diodes. I'll get you the schematic later today.
Old Mar 3, 2008 | 06:28 AM
paracoche's Avatar
I have the installation photos but I can't upload here.
if you want can contact me.
Old Mar 5, 2008 | 02:25 AM
rsdriver17's Avatar
Default Re: (paracoche)
so wait where do i get a relay ?
Old Mar 5, 2008 | 11:03 AM
striker_18's Avatar
Default Re: (rsdriver17)
relays can be bought on ebay...
has to be 30-40A relays
Rodney Williams
Lighting
Oct 30, 2014 08:45 PM
ef yu
Lighting
Mar 15, 2010 09:20 PM
crist488
Sep 14, 2009 02:22 AM
itsmejto
Jun 22, 2008 04:11 AM
Evil_Wizard
Mar 7, 2002 09:53 AM
