Lighting HID/Xenon kits, Retrofits and Associated Topics
Need help! searched!
Old Mar 25, 2008 | 07:41 PM
lovelife6431's Avatar
Default Using cruise control switch to run fogs?
Problem solved!
Modified by lovelife6431 at 8:44 PM 3/31/2008
Modified by lovelife6431 at 9:56 AM 4/6/2008
Old Mar 27, 2008 | 04:12 PM
Default Re: Need help! searched! (lovelife6431)
Anyone?
Old Mar 31, 2008 | 07:46 PM
Someone please help!
Old Apr 5, 2008 | 07:12 PM
bump
Old Apr 5, 2008 | 07:29 PM
bpr0422's Avatar
Default Re: Using cruise control switch to run fogs? (lovelife6431)
it would be easier to run them as drls, or have them turn on with your parking lights.
make a wiring harness.
Run a fused wire from the battery, to terminal 30(common) on the relay
From terminal 57, run that to the positive lead on the foglights.
ground the lights to the chassis (easy ground is the one on your rad support, where there is a ground wire from the valve cover)
Then run a wire from the fuse box (either into the light switch accessory, or the accessory spot) into the engine bay.. and connect that to terminal 85
and then ground terminal 86 to the chassis.
I recommend 14-12 gauge wire for the battery, and the lights, and the light's ground.
while 20-18 gauge for terminals 85/86 is good enough.
you will need to know how relays work:
http://www.the12volt.com/relays/relays.asp
and how to solder... read the [how-to] Car Security thread to learn how to make proper connections.
Old Apr 5, 2008 | 08:25 PM
Default Re: Using cruise control switch to run fogs? (bpr0422)
bpr0422 thank you sooo much! I just needed to know where to connect this ****
JDMarshal
Lighting
Aug 3, 2010 03:44 PM
michael-crxsi
Sep 30, 2009 06:54 AM
b18c1vtecdc2
May 29, 2009 10:29 AM
b18c1vtecdc2
Lighting
Mar 24, 2009 09:21 PM
JDMCRX
Jul 8, 2008 07:11 PM
