Lighting HID/Xenon kits, Retrofits and Associated Topics
Halo help on EJ1
Old Mar 28, 2008 | 11:11 AM
ErikFlipside's Avatar
Default Halo help on EJ1
I recently bought a 95 EX from my brother's friend after my 94 LX got hit. The car came with some nice projector headlights but the halos aren't wired up. I finally got some time last night to take a look at the wiring and cannot figure out where to wire them up. There are two halos per headlight, so I've got two hot and two ground wires hanging out. I took the side marker / turn signal harness off the corner light thinking I could splice into it, but when I tried testing out whether or not the halos would light up, they wouldn't. They're supposed to come on when you turn your headlight switch to the first position, correct? For some reason I could only get them to light up when I had them hooked into the harness and the turn signal was on...and then the halo would just blink like the indicator would. It was pretty frustrating. There are three wires in the harness going to the side marker light...red, black in the middle, and green.
What should I be doing??? I can post pictures if needed...
Old Apr 1, 2008 | 04:03 AM
Bump.
Still looking for some advice. Thanks.
mikecp
Jan 20, 2020 02:19 PM
gooblinn258
Jan 11, 2014 01:33 PM
dajman94
Nov 16, 2005 04:52 PM
HoNdAeX11
Jul 21, 2003 02:53 PM
