Lighting HID/Xenon kits, Retrofits and Associated Topics
Help with H4 Connection
Old Apr 20, 2008 | 08:34 PM
EK_B's Avatar
Default Help with H4 Connection
Sample of an H4 male connector:
There is one on top and two on the sides, which ones are the negative and which ones are positive? Thank you.
Old Apr 20, 2008 | 08:50 PM
bpr0422's Avatar
Default Re: Help with H4 Connection (EK_B)
Looking at the bulb:
Old Apr 21, 2008 | 07:12 AM
EK_B's Avatar
Hmmm, you're diagram looks like it differs from these instructions:
20. Wire configuration of HID wiring to OEM Headlight wire harness. (Facing connector; TOP is positive wire [RED] and BOTTOM RIGHT is ground wire [black].
Am I mistaken?
Old Apr 21, 2008 | 05:02 PM
bpr0422's Avatar
Default Re: (EK_B)
i forget if the diagram was looking at the harness on the car, or on the back of the bulb...
i think it was looking at the back of the bulb.
also my diagram shows no + or - terminals..
H4 lights are either positive or negative triggered..
meaning their common is either ground or positive.
depending on the year of the car, it could be positive or negative triggered.
easiest way to figure it out, is to use a multimeter.
civic_loner22
24
Mar 18, 2011 07:39 PM
Paul-eg
Lighting
Feb 15, 2009 09:35 AM
xoutlawz00x
Oct 29, 2005 05:11 PM
ek_will
Mar 16, 2005 07:35 PM
specie
Jan 23, 2005 11:46 AM
