Lighting HID/Xenon kits, Retrofits and Associated Topics
LIGHTING PROBLEM
Old Mar 30, 2008 | 02:44 PM
B16B_coupe's Avatar
HRD PKR
Default LIGHTING PROBLEM
Ok so my friend has a 90 civic dx with an ls swap.
He is having a wiring issue after removing the dash and re installing.
ON with the problem.
When you turn the key to the on position the engine light stays lite ( there is no engine light) When you turn the turn signal or the headlights on the engine light goes off.
When you use the flashers key off: the driver speaker makes a noise and the flashers lite up but dont blink or anything.
Checked the grounds on both sides for the headlights and the one on driver side under dash by relay.
Any help would be great! Thanks
Old Mar 31, 2008 | 03:14 AM
B16B_coupe's Avatar
HRD PKR
Default Re: LIGHTING PROBLEM (B16B_coupe)
Old Mar 31, 2008 | 12:55 PM
B16B_coupe's Avatar
HRD PKR
no one?
Old Mar 31, 2008 | 01:04 PM
grog's Avatar
that is really odd.
maybe some wiring is being pinched/crushed behind the dash.
so all this happened after simply removing and re-installing the dash, and It all worked before hand?
BTW your blinker (flasher) should not function at all with the ignition off.
Old Mar 31, 2008 | 01:42 PM
B16B_coupe's Avatar
HRD PKR
Default Re: LIGHTING PROBLEM (grog)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grog &raquo;</TD></TR><TR><TD CLASS="quote">that is really odd.
BTW your blinker (flasher) should not function at all with the ignition off. </TD></TR></TABLE>
The flashers should always work key on or off. (hazards)
all grounds are good to, My only guess is that something is pinched
Yep all he did was remove it and reinstall it and now this. it all worked before
Old Apr 1, 2008 | 02:56 AM
B16B_coupe's Avatar
HRD PKR
Old Apr 3, 2008 | 02:24 PM
B16B_coupe's Avatar
HRD PKR
Problem fixed sweet
Old Apr 3, 2008 | 08:38 PM
grog's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16B_coupe &raquo;</TD></TR><TR><TD CLASS="quote">Problem fixed sweet </TD></TR></TABLE>
So what was it?
Old Apr 4, 2008 | 05:18 AM
xmsleepR's Avatar
OBD0 for you...I've heard a couple stories of weird **** happening like that in swapped OBD0s
Old Apr 5, 2008 | 04:33 AM
B16B_coupe's Avatar
HRD PKR
So what was it?</TD></TR></TABLE>
He swapped a plug on the fuse box, We got it fixed for him
Deafkid2005
Apr 22, 2014 07:51 AM
EDCorey
Apr 10, 2011 08:49 PM
bquinn702
18
Jan 4, 2009 12:15 PM
