Lighting HID/Xenon kits, Retrofits and Associated Topics
Anybody with HID ?
Old May 25, 2008 | 08:39 AM
DrivenMC's Avatar
Banned
Default Anybody with HID ?
We are Sponsoring Honda-Tech to try and aid all HID ? From Retrofits to Conversions. Open to Any ?'s Wiring trouble, ballast issues, bulb outs, Etc
Old May 25, 2008 | 04:36 PM
EK_B's Avatar
Why do the Chinese ballasts break so easily as compared to the German ballasts?
Old May 25, 2008 | 05:17 PM
DrivenMC's Avatar
Banned
Default Re: (EK_B)
It's All about Supply and Demand, I've been building HID ballast for 8 years and my Conclusion would be that Asia Can Build Low To High Quality its all about who will Spend the Money. So you asked why do Chinese ballast break, well if you want a $100 hid kit than thats what your getting.
Quality Cost- Most people just want the product. They don't care about Quality So this is why you have HID companies producing cheap kits for mass production.
90+% of Ballast internals come from Asia, Even "German Ballast"
Old May 27, 2008 | 09:08 AM
David1978's Avatar
Default Re: Anybody with HID ? (DrivenMC)
I just picked up a set of JDM Honda HID headlights on Ebay for my 2004 Honda Civic Hatchback.
After looking at them, the seller never sent me the wire harnesses for the drivers side headlight and I had to make do with spade connectors for now. Also, after wiring the passenger side up and splicing the wires from my American version car, I noticed that there are I think 4 lights: Turning signal, running light, main light and bright light. I have them all wired wrong and I have no skematic to figure out which one goes where.
Is there anything you can tell me?
Dave
Old May 27, 2008 | 12:14 PM
devani's Avatar
Default Re: (DrivenMC)
do you have a wire harness for positive H4 and using separate bulb for DRL and Hi beam for solenoid....?
Old May 28, 2008 | 07:34 AM
DrivenMC's Avatar
Banned
Default Re: (devani)
On the JDM headlights, I need pictures.
Old May 28, 2008 | 07:37 AM
DrivenMC's Avatar
Banned
with the Harness, If you could explain a little more it will be helpful.
Old May 28, 2008 | 10:48 AM
devani's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DrivenMC &raquo;</TD></TR><TR><TD CLASS="quote">with the Harness, If you could explain a little more it will be helpful. </TD></TR></TABLE>
Honda 08 CR-V has DRL...bulb is H4...so it's Lo and Hi/DRL...
But I need a wire harness so that when Lo beam is on, DRL and Hi beam is off...obviously
also when DRL is on Lo and Hi beams are off...also obvious
and When Hi beam is on DRL is off and Lo beam is on(for bixenon retro). Thanks.
and I also mentioned that it's positive switched H4
Old May 28, 2008 | 06:45 PM
djsonic's Avatar
Do you know which prongs are what on a 97 honda civic (h4)?
Old May 29, 2008 | 07:06 AM
DrivenMC's Avatar
Banned
devani, I have a harness that works with our HID system for H4 Bi-Xenon, However you will loose your DRL lights.
Old May 29, 2008 | 11:53 AM
devani's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DrivenMC &raquo;</TD></TR><TR><TD CLASS="quote">devani, I have a harness that works with our HID system for H4 Bi-Xenon, However you will loose your DRL lights. </TD></TR></TABLE>
that's fine as long as it works on Lo beam and high beam.
Old May 29, 2008 | 11:55 AM
DrivenMC's Avatar
Banned
So which HID system Do you have?
Old May 29, 2008 | 12:03 PM
devani's Avatar
it's retro...so everything's OEM...FX35 projectors, Matsushita Gen 3 ballasts and philips D2S bulbs...
retro on my car is already done...it's my wife's CR-V that needs retro bad....and to make it worse CR-V has DRL and that's the only thing bothering me.
Old May 29, 2008 | 08:01 PM
DrivenMC's Avatar
Banned
I've got a NEW style Bi-Xenon Projector Retrofit in R&D, I'm going to post up a thread tomorrow to see what interest it Generates. I don't see a problem in working with you on a wiring harness. Thats why we Have a Engineering Department.
Old May 30, 2008 | 04:16 AM
devani's Avatar
it will be interesting to see new products...floods of china products and it would be nice to see some good products....
I would like to see some results for the wire harness..
Old May 30, 2008 | 04:18 AM
DrivenMC's Avatar
Banned
Just let me know How I can help
Old May 30, 2008 | 11:52 AM
devani's Avatar
Something like this would be fine not too fancy, as long as I know where each pin goes...
Old May 30, 2008 | 06:03 PM
Arman's Avatar
do you guys sell relays for the cars that flicker?
Old May 30, 2008 | 06:18 PM
DrivenMC's Avatar
Banned
Default Re: (Arman)
Yes, I do have relays. Which car are you talking about that flickers? It might need more than just a relay.
Old May 31, 2008 | 07:18 AM
DrivenMC's Avatar
Banned
Here is our new retro-fit, its still in the development stage. Let me know what you think.
Old May 31, 2008 | 10:05 PM
y7turbo's Avatar
when i turn on my hid's the right one starts out redish for about 1 second than goes to the normal color. I have no idea what to look for with this problem, any ideas?
matsushita ballasts, d2s 4300k phillips bulbs fx 35 projectors.
thanks for any help.
Old May 31, 2008 | 11:25 PM
bpr0422's Avatar
Default Re: (y7turbo)
bulb age...
stop turning them on and off rapidly...
doing that significantly reduces the life of a bulb...
Old Jun 1, 2008 | 06:23 AM
y7turbo's Avatar
Default Re: (bpr0422)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bpr0422 &raquo;</TD></TR><TR><TD CLASS="quote">bulb age...
doing that significantly reduces the life of a bulb...</TD></TR></TABLE>
bulbs were new when i got them, and they have been on the car for about 4 months. i dont turn them off and on. they could be off for a few days and when i go turn them on the right one has that problem.
Old Jun 1, 2008 | 06:48 AM
DrivenMC's Avatar
Banned
Depending on the bulb batch#, It sounds like the gas mixture isn't correct. So has it always done that?
Old Jun 1, 2008 | 07:14 PM
y7turbo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DrivenMC &raquo;</TD></TR><TR><TD CLASS="quote">Depending on the bulb batch#, It sounds like the gas mixture isn't correct. So has it always done that? </TD></TR></TABLE>
no it just started about a week ago. ill switch bulbs with the other side and see if the problem follows to the drivers side. then ill know if its the bulbs.
